How to requests and questions Please post your requests and questions for How to Guides.
help
Old Jul 11, 2016 | 01:23 AM
bengee's Avatar
help
My car wont go in to any gears when i push the clutch in it wont get anything i can go in a circle with my gear stick what piece is needed to fix this and what is the problem. I cant get no gears if car is off i was driving the car with no clutch one day and then all off a sudden i couldnt Get any gears
Old Jul 11, 2016 | 12:12 PM
jcobaltss's Avatar
Google roll pin Cobalt ss
Old Jul 11, 2016 | 01:37 PM
double clutch's Avatar
Take off your driver side wheel and you should be able to see the shifter cable bracket. Make sure both cables are still attached
Old Jul 11, 2016 | 09:52 PM
bengee's Avatar
I ll have someone Check tommorow
Old Jul 11, 2016 | 09:53 PM
bengee's Avatar
Can u show me a picture of what its sopposed to look like or what im looking for
Old Jul 11, 2016 | 10:09 PM
Not the bracket that circled but the two cables above it. Make sure they are still connected. Also remove your shift boot and make sure the cable clamp is still snapped onto the bottom of the shifter. These are the easiest things to check so you should check these first.
klotzy_550
Aug 19, 2016 01:33 PM
CudaJoe
40
Aug 16, 2016 12:52 AM
umrdyldo
Jul 1, 2016 07:44 AM
BoostedSSBalt
Jun 19, 2016 07:59 PM
zzech
Jun 14, 2016 10:20 AM
