Contacts: JM Auto Racing
Megan Racing Coilovers
Old Nov 28, 2010 | 04:04 PM
  #51
JM Auto Racing's Avatar
bump bump bump
Old Nov 28, 2010 | 04:09 PM
  #52
carstedt's Avatar
i bought mine brand new and i wouldnt have gone ne other route..ther great ride smooth, easy to adjust and great height choice
Old Dec 5, 2010 | 06:07 PM
  #53
bump bump bump
Old Dec 12, 2010 | 07:11 PM
  #54
All PMS sent. Bump to top
Old Dec 16, 2010 | 05:33 PM
  #55
All pms replied to
Old Dec 19, 2010 | 05:39 PM
  #56
Get in your last minute Christmas shopping in. Rush delivery available with guaranteed delivery before Christmas.
Old Dec 26, 2010 | 09:38 PM
  #57
All PMS replied too
Old Jan 2, 2011 | 05:36 PM
  #58
all pms replied!!!
Old Jan 9, 2011 | 08:14 PM
  #59
All PMS replied!!
Old Jan 16, 2011 | 07:04 PM
  #60
All have been PMS Replied!!
Old Jan 20, 2011 | 05:28 PM
  #61
Updated on all Megan Prices. Free Shipping over $100.
Old Jan 20, 2011 | 05:38 PM
  #62
Chevy Cobalt SS 06+
JM Auto Racing - View our aftermarket auto parts catalog
Model Number : MR-CDK-CC06
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: Front 6kg/ Rear 6kg
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
MSRP: $1050.00
Old Jan 24, 2011 | 08:36 AM
  #63
Bump bump bump
Old Jan 30, 2011 | 06:49 PM
  #64
All PMS REPLIED!!!
All PMS REPLIED!!!
Last edited by JM Auto Racing; Jan 30, 2011 at 06:49 PM. Reason: Automerged Doublepost
Old Feb 3, 2011 | 05:40 PM
  #65
all pms sent
Old Feb 3, 2011 | 06:06 PM
  #66
lebulbe's Avatar
is the car handle will be increase significantly with those on ?
Old Feb 3, 2011 | 06:17 PM
  #67
without a doubt
Old Feb 6, 2011 | 05:09 PM
  #68
Bump bump bump!!
Old Feb 13, 2011 | 05:51 PM
  #69
ALL Pms Replied!!!
Old Feb 20, 2011 | 06:32 PM
  #70
All pms replied!!
Old Feb 27, 2011 | 03:40 PM
  #71
BUMP BUMP BUMP
Please be advised we are having some technical difficulties with the site and it should be working again shortly
Old Mar 6, 2011 | 05:20 PM
  #72
All pms replied!!
Old Mar 13, 2011 | 04:47 PM
  #73
All pms replied!!
Old Mar 20, 2011 | 07:44 PM
  #74
All pms replied!!
Old Mar 27, 2011 | 06:39 PM
  #75
All pms replied
