Contacts: JM Auto Racing
Projector Headlights with O-Nex HID KIT Combo
Old May 11, 2010 | 03:49 PM
JM Auto Racing's Avatar
For sale are Sonar Projector Headlights. These headlights use real HID projectors, not halogen projectors which will give you a better light pattern and a better output. This will also help control the cracking that normal halogen projectors face and have a more focused cut off pattern. They include a 3 year warranty form all mechanical issues. Headlights are available in chrome and black housings. Fitment is perfect and will allow no leaks.
The HID kit is not your cheap average HID kit. Its produced by ONEX. The available temps are available from 4300k - 12k. Additional colorrs available at additional costs. The kits are digital, not magnetic which will allow these to last longer. They are also backed by a lifetime warranty against all defects on the ballasts.
3rd Gen
$299
1st Gen
$299
4th Gen
$349.00
CCFL Styles Available Also. Please contct for pricing.
Some customer photos of the 3rd Gens
Last edited by JM Auto Racing; May 11, 2010 at 03:49 PM. Reason: Automerged Doublepost
Old May 11, 2010 | 03:58 PM
G Speed's Avatar
any pics of 4th gen installed?
Old May 11, 2010 | 04:05 PM
unfortunately there not the most popular and I have only sold like 2 or 3 sets. I found this though. Granted its photoshoped but you get the idea
http://i616.photobucket.com/albums/t...cobaltgen4.jpg
Old May 11, 2010 | 04:09 PM
ChevyRockstar's Avatar
Do you all price match? because i belivie i've seen the gen 1 and 3s With CCFL halos already for slightly less then yours
Old May 11, 2010 | 04:19 PM
I will price match to an extent but keep in mind. These prices are includig the HID kit as well, not just the headlihts.
Old May 11, 2010 | 04:20 PM
Reading>me
i didn't see that thanks
Old May 11, 2010 | 04:26 PM
Newf_ss's Avatar
can you guys just sell the headlights..I have HID's comming when there off back order
Old May 11, 2010 | 04:28 PM
Yes I an pm sent
Old May 11, 2010 | 04:30 PM
116Fanatic's Avatar
SOUNDS AWESOME!! More than likely will buy! Couple Qs: "cracking that normal halogen projectors face.." is this on the glass?
Also whats the price for 1st gen CFFL?
Old May 11, 2010 | 04:47 PM
What happens on lights that are not meant for HID, the halogen projector lense is too weak to withstand the HID intensity and will start to deteriorate. The light will scatter and make actually start to melt the harness and housings. THe HID projectors will not do that.
The CCFL 1st Gen with HID kitis are 325
First off it illegal because they dispurse a glaring light.
HIDs run COOLER than halogens (at the same wattage). To put it simply:
55W = Light Output + Heat Output. If you increase the light output, then obviously the heat output has to decrease. That being said, the intense Blue to UV radiation (especially in kit bulbs which don't filter as much of the UV out) has been known to cause the chrome to bubble or fade. I can get into the background of why it happens but for clarities sake won't. Just know it is a result of the increased Blue-UV radiation.
Last edited by JM Auto Racing; May 11, 2010 at 04:47 PM. Reason: Automerged Doublepost
Old May 11, 2010 | 05:34 PM
116Fanatic's Avatar
Ordered
Old May 11, 2010 | 06:20 PM
order being processed!!!
Old May 15, 2010 | 01:29 PM
evZO6's Avatar
Are these plug and play or do they require cutting into the stock wiring
Old May 15, 2010 | 10:26 PM
100% plug and play
Old May 15, 2010 | 11:15 PM
Omnigear's Avatar
post price w/o the hid kit
with them.
Old May 15, 2010 | 11:27 PM
Acey's Avatar
HID's of any variety require the DRL fuse to be pulled on '07+ cars, right?
Old May 16, 2010 | 05:08 PM
Yes DRL + HID = No good.
I believe the price without the HID kit is 189 ps and you get a 10% discount if you use code JMGO10
Last edited by JM Auto Racing; May 16, 2010 at 05:08 PM. Reason: Automerged Doublepost
Old May 23, 2010 | 06:50 PM
bump bump bump
To add to the DRL issue, with the projectors installed, you don't need to worry about the DRL
Last edited by JM Auto Racing; May 23, 2010 at 06:50 PM. Reason: Automerged Doublepost
Old May 25, 2010 | 05:17 PM
116Fanatic's Avatar
I cant figure out how to install the HID bulb into the projector?? How do I replace the old bulb and get it inside the rubber grommet? Also, where do the red and black wires connect to? Do they connect to the brown & black where you wire the parkings??
Old May 25, 2010 | 06:40 PM
If you take some pictures and send them to my email I can walk you through it. As far as the parking lights are concerned, you need to test which one is pos and which one is negative and hook them up via the matching wires on the lights
Old May 27, 2010 | 09:52 PM
another set sold to girlsetfire
Old May 28, 2010 | 06:09 PM
remeber to use the discount cod for the 10%!
Old May 31, 2010 | 08:20 PM
bump bump bump
Old Jun 2, 2010 | 10:16 PM
2 more third gens sold!!
Old Jun 4, 2010 | 01:21 PM
BigSid81's Avatar
so 4th gen doesn't have the led's? and can I choose something besides the 4300k?
