Kc Peoples!
well I just "googled" it... hahaha... seems fairly easy... especially since I have an Automatic... I might give it a try... I just want to get my car on the track to see what it can do...
Make sure that your battery is securely mounted (factory mounting is OK) as the tech guy will grab the battery to see if it is loose.
Make sure you have all of your lug nuts on your wheels.
If you have modified the cooling system, you must have a catch can for radiator overflow.
Don't run your A/C as that leaks condensation on the track.
If you have nitrous in the car you will need a fire jacket even if you are not spraying your car.
Above all, watch the track crew and follow thier instructions.
Have fun and don't forget to stop and pick up your timeslip from the timing shack on the way back to the pits.
Rent me! per hour
spanky!
whud up dewd
springer. that in a nutshell is it.
remember. stage with the front tires. not the back. you will get laughed at.
also, stay OUT of the water box on street tires. you only hurt yourself with this.
whud up dewd
well aight...
thnx for the info... I'm not expecting ANYTHING great at all... just some fun... hopefully I'll see y'all there... I'll be the one with the absurd looking rims...
I'll prolly take the chrome pieces off though
I'll try to be there around 7ish
Last edited by springerdesigner; Aug 29, 2008 at 04:49 PM. Reason: Automerged Doublepost
Don't forget if you want to run your car you have to have long pant's. oh any one see the red ss cobalt on the news that got tagged with spray paint, wanted to see if he was a member i think his name was ryan or something
lets go get some ****** french toast
I picked up another stall at work. no lift though. just a flat stall and a lift
bryan i got your scanner, kinda. you can give me 90 for the new one or 50 for my old one. the new one is bigger and does freeze frames for the codes the other just reads codes.
