Mid Central NE, KS, IA, MO, and IL
stage 2 problem
Old Sep 10, 2009 | 07:25 PM
SPAETH42's Avatar
stage 2 problem
i got my pmc form zzp stage 2 with pully n 42injectors and its started up fine but it throwing 2 dtc codes, misfire cyclinder 4, and evap system i was wondering if anyone know wtf is going on???
Old Sep 10, 2009 | 07:55 PM
Sizzle06's Avatar
You might have to do a case relearn and the evap code is probably a sensor or hose unplugged.
Old Sep 10, 2009 | 08:00 PM
Black SS 07's Avatar
check your gas cap.. for evap..
and you probably didnt seat the injector all the way try to reseat them. check for pinched o-rings
Old Sep 10, 2009 | 08:36 PM
SPAETH42's Avatar
well my changed out the injector out of cylinder 4 and put in it cylinder 3 and erased the codes and than cylinder 3 came up with a misfire. so theres the obvious there. that injector that they sent me is messed up. but now my question is, after gettting another injector and clearing the codes, with evap still pop up or could it be poping up because of the misfiring that is going on. bc i checked for all things that it could be befre starting to replace things. all plugs are in sensor to the solinod is pluged in. so after taking care of the misfire, could the evap possiblily go away with that issue?
Old Sep 10, 2009 | 08:48 PM
did you buy the injectors used? because zzp flow matches all of their products.. so there shouldnt be a problem if its new..
Old Sep 10, 2009 | 08:50 PM
SPAETH42's Avatar
saddly it was used. but they posted saying its all working, so still a lil messed up.
Old Sep 10, 2009 | 08:55 PM
dang.. that sucks lol
i would try to get your money back or be at least repaid a little to get a new inject from someone.. i know its a stupid reason but just rule it out... check the connecton on the injector. see if its dirty or bent.
Old Sep 11, 2009 | 12:44 AM
SPAETH42's Avatar
switched out the injector with the stock and it ran fine for now so all i need is a new #42 injector does anyone know where to find 1 not 4
switched out the injector with the stock and it ran fine for now so all i need is a new #42 injector does anyone know where to find 1 not 4. also i know some one that has a hp (AJ) and he look at the tune i got from zzp and its hella shitty never again fu*k zzp!!!!!
Old Sep 11, 2009 | 12:47 AM
Rodimus_Prime's Avatar
are those the lucas injectors summit racing possibly may have one? im sure zzp could send you just one
Old Sep 11, 2009 | 12:57 AM
now that is just ignorant..... ive never had a faulty product from zzp. if you knew anything about the company you would respect them and their work...
but hey what do i know... i just have 2 cars powered by them.. and a customer since early 2006
not to be a dick but theres no way your car would run correctly with a stock injector and 3 42's......
Old Sep 11, 2009 | 06:35 PM
SPAETH42's Avatar
no **** but it runs bettter than with the faulty one they sent me till i get my 4th, u lucked out ive had more than just this one prob with them
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
