Modern Performance Modern Performance is a Supporting Vendor
contacts: Modernceo
Aeroforce PLUG and PLAY DUAL Scangauge now in stock!
Old Feb 10, 2009 | 10:11 PM
Modernceo's Avatar
For those of you who havent seen these on our website..
We are now keeping IN stock the Aeroforce SCangauge. This gauge plugs into your OBD2 port, and connects to your vehicle in minutes!
Heres the parameters it will display:
This Dual gauge setup will allow you to monitor 4 lines of parameters whereas the single gauge setup will show 2 lines of parameters.
Want a gauge that can be installed and running in less than 15 minutes that can monitor all of these parameters?
# RPM
# MPH
# Intake Air Temperature pre intercooler
# Intake Air Temperature post Intercooler *
# Mass Air Flow Sensor Frequency *
# Mass Air Flow Sensor (lb/min.)
# Engine Coolant Temperature
# Injector Pulse Width
# Long Term Fuel Trim
# Short Term Fuel Trim
# O2 Sensor Voltage
# Manifold Pressure in PSI (Boost pressure)
# Ignition Advance
# Knock Retard *
# Engine Run Time
# Battery Voltage
# Throttle Position Percentage
# Engine Load
# Instantaneous fuel economy
# Horsepower
# Analog input #1
# Analog input #2
Want more information? Click on the link below..
Dual Gauge for 05+ 2.2 and 08+ SS Turbo
http://www.modernperformance.com/aer...lt-p-1853.html
Dual Gauge for 05-07 SS Supercharged
http://www.modernperformance.com/aer...lt-p-1850.html
ineedacobaltss
Nov 7, 2015 02:25 PM
717ssbalt
Oct 2, 2015 04:01 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Sep 27, 2015 08:53 PM
