ideas for new electronic products
if there is something in particular you guys would like to see made for your car please by all means post up or pm me or jon.if we like the idea we just might put it in production
PFT! How about something that will scramble radar/laser guns the cops use AND do the same to those ******* redlight and speed cameras. Build that and put me down for one.
How about something that allows those of us who don't have an I-Pod jack in our car to play our I-Pods without having to use an FM modulator or hacking into our factory harnesses....
Or How about a harness that will allow us to swap out the 05-06 radio for the 07-08 with the I-Pod jack and 6 disc CD Changer...
I bought an FM modulator and it was the biggest waste of money, I don't even use it anymore cause the quality is so bad. 140 bucks down the drain!
ummm electronics wise... let me think...oh i kno
a proper fan switch kit. all you would have to do is make a relay with the wires built in for the switch. rite now MOST people including myself have some heavy guage wire stuck inside one of the pins on the fan relay.
make it one simple kit. not that hard to do.
Go a step father. I have been saying for years that two a GPS and a Radar detector company should get together. Imagine have a GPS that could give you a visual warning of where the cop is and you could identify hot spots.
http://www.pie.net/pie_store/shopexd.asp?id=656&bc=no
I agree, I would like this as well.
I would like one that allows you to turn on the IC pump as well as the two fans and be able to adjust them. (50% or 100%) I have this now but it's more or less just a rigged up rocker switch.. I'd like a more refined solution. Great for the track.
What are these IC pumps and fans you speak of? Do you mean the radiator fan?
The intercooler pump and yea the radiator fans. Here's what some of us have done curtesy of wopontour:
https://www.cobaltss.net/forums/show...ht=pump+switch
I don't particularly like jumping the relays to do this but I'm not smart enough to come up with a better solution.. help?
can't you do this with the interceptor? it has controls for fan high and fan low.
