Wanna swap suspension to sport from soft ride
Old Aug 26, 2022 | 09:41 PM
redrummenace's Avatar
What do i have to do to make the swap from fe1 soft ride to fe3 or fe5 sport suspension 2009 coblat lt 4 door non abs loaded beam axel rear!!! Also do i need to go to a full independent suspension or can I stay with the loaded beam axel!!!
Old Aug 27, 2022 | 01:47 PM
Monieg5gt's Avatar
Honestly the better option is to swap over to aftermarket completely with zzp suspension parts. They have lowering springs, coil overs, rear sway bar, front strut bar etc. For struts you can go with kyb excels or sachs brand struts. Rear shocks bilsteins or you can still get fe5 gm shocks for sale on rockauto. Also with all those upgrades are you going to upgrade your old worn out bushings, tie rod ends, sway bar end links, sway bar bushings? If you want the most out of your new suspension you will have replace all those old worn out bushings. I went through this entire process and redid all of my suspension including engine mounts and tranny mounts.
Old Aug 27, 2022 | 06:21 PM
So leave the natural set up i have and just upgraded everything!?
Old Aug 27, 2022 | 09:28 PM
Monieg5gt's Avatar
Yes exactly! Check out Ecotec – ZZPerformance and Welcome to Over The Top Performance -
Old Aug 27, 2022 | 09:51 PM
Ok sweet thank you very much
Old Nov 21, 2022 | 03:52 AM
alfredodemarcoss's Avatar
Old Nov 21, 2022 | 07:12 PM
slapbetcommissioner's Avatar
all suspension setups for the cobalt will retain the twist beam. No version of these came with independent suspension.
ml2242
Mar 2, 2016 07:16 AM
Paprika
Oct 25, 2015 01:16 PM
Ph3lix_004
Jul 31, 2011 07:11 AM
Shermen
Dec 18, 2006 09:02 AM
