Wth is up with my tranny?
Old Mar 18, 2017 | 06:04 PM
VALNIKO123's Avatar
I need help! I'm new to the forums, bought a 06 ss/sc with 90k, it's been about two weeks since I got it.. when I firstry test drove it it was perfect! Engine and sc are strong! Tranny would shift pretty good considering the clutch was starting to go (barely)... but just recently it's getting harder and harder to put into gear.... ESPECIALLY REVERSE!....is it the clutch? The tranny ? The syncros? The master/slave cyl? Anyone else have this problem?
Old Mar 30, 2017 | 07:29 PM
kcpoloman's Avatar
Might try changing the transmission fluid.
Old Mar 30, 2017 | 08:53 PM
HeavyChevyLNF's Avatar
Most likely the the clutch isn't fully disengaging. I would start with changing the fluid in the master and slave.
Old Mar 31, 2017 | 02:07 PM
These transmissions are ******. Shift into first then into reverse
Old Mar 31, 2017 | 04:39 PM
cw383's Avatar
My guess is either shifter adjustment or shifter cables. Find good shifter adjustment directions below, and while you are in there pop each cable off and confirm it isnt binding.
https://www.twmperformance.com/short...short-shifter?
Old Apr 5, 2017 | 02:43 AM
05baltss25's Avatar
I recently removed the transmission in my 2005 cobalt Ss supercharged to replace the clutch this meant removing the fuse box and ecm. I now am not able to start the car. Battery has 12.6 volts cranks, have fuel, have spark. Is there something I have to do to reset everything or anything I need to do?
Old Apr 5, 2017 | 01:52 PM
royce777's Avatar
Pull the fuse box and check all the tabs on the bottom.
Also Im not too familiar with the LSJ cobalts but I believe there is a ground somewhere that bolts to the tranny
Old Apr 5, 2017 | 02:21 PM
05baltss25's Avatar
Checked over everything is plugged in and where it needs to be engine just won't fire
Old Apr 5, 2017 | 02:24 PM
royce777's Avatar
Did you pull the fuse box and look at all the tabs on the bottom? Make sure none are bent.
Old Apr 5, 2017 | 02:56 PM
cluelessk's Avatar
Betting it's stretched cables or adjusted incorrectly.
