50 shot?
So seriously now, why you back in NJ. Better employment or something?
Really, I think I am turning pro this summer. My coach, Lindsey Lohan, tells me I still need a little more work. Really I am just playing dumb so I can keep have her demonstrat the procedure to me over and over again. I really could of turned pro along time ago, when I was like 13.
lol
Yeah, everywhere but up her nose. She is not the brightest light in the toolshead, has about as much sense as god gave a goose. That is why she is the perfect coach for the pro level of Jacking off, she thinks she is teaching me when really she is just enertaining me in a perverted sort of way.
She wrecked your old cobalt, not you. lol
Shishhhhhhhhhhhh!!! I do not want the insurance companies to find out. She still tells me she just hit a dog and that is it, but I bet she will tell me the truth when I threatin to make Paris Hilton my coach instead of her. It may be the best for my career to tell you the truth. Paris sent me a video resume, and it looks like she is used to dealing with big equipment.
Gess I spent too much time with people who have been running N20 for decades at shots higher than our LSJs make stock (ls1tech). The Cobalt must be a lot more brittle and prone to failures than I thought.
Dry shots "hit" softer than a wet kit will and are a little easier on internals. Make sure if you use a dry shot you spray befor the MAF. The MAF sees the extra airflow and add fuel. As long as you do not tap out the injectors drys are safer on your car. 50 shot set up right should last a long time.
2. The MAF will NOT be able to comphensate fuel. A stock computer with a MAF setup is capable of making slight fuel table changes if there are airflow changes.
3. It's not safe if you don't have a proper fuel management setup that is prepped for spraying. It's much more of a hassle to do everything through your computer and you would literally need 2 seperate "tunes" and probably oversized injectors in the first place. A wet shot is much safer to run. If you're saying a dry shot is safer because of backfiring from fuel puddling, this typically happens when people spray from a launch and are at low RPMs, meaning, less engine revolutions and less intake strokes. There is being more wasted fuel especially being that it sprays at a constant flow and not like how your injectors spray during only intake strokes. Fuel gets backed up and the heat from the engine can ignite the fuel pre-combustion chamber causing a backfire.
If you ultimately want to avoid even that, you can do a direct port injection setup...but that's if someone wanted to get real serious into it.
If the people you know who were blowing engines up left and right thought exactly what you just said before, there is no question why.
I could of sworn the PCM on the Cobalts was similar to the one chevy uses on about every other car. I will have to look into this as well as the MAF used on the Cobalt. 99% of dry kits ues the MAF and PCM. Only seen one N2O car nuke. He was spraying multi dry shots (300hp iirc). FYI the car did not let go because of the N2O. After More trips down the track than any 20 Cobalts and being the 2nd fastest stock block M6 Zo6 in the world, He was due for a new motor.
as far as internals go on the 2.4 yes a 50 shot 75 will work on the 2.4 but i can tell you the intake mani wont hold it and fuel puddling will occur. i think you would need a fuel collector or something maybe im wrong i dont remember what it was. but ive seen bad things with to much n20.
ryan.
ryan.
ryan.
ryan.
No matter what manifold you get for your car, it's a dry manifold meaning that it's only nature is to carry oxygen, not liquids. Fuel puddling can occur in any dry manifold.
+ 1^^^ on what he said. my son had a 04 2.2 and he ran a 50 dry shot. his times at the track were a constant low 14's, i personally raced the car and it was quick for just a 50 shot. now what he didn't do was the reason the engine let go. if you use a dry shot you need to get colder plugs and reduce the timing about a degree. this will not let the cylinders heat up and break the rings as his did. and he also put the system in front of the maf. bad no no!!! if you run a wet shot as mentioned above, this will improve you get more hp and tq to the whls, and it is alot safer to run. as the system puts the correct amount of fuel in to mix with the amount of nos you are running. a dry shot is not a very good way to make good hp. go wet, spend a little more money and have alot lett problems in the future. and there are 2.2 engines everywhere in salvages. we bought him one for 400$ with 18000 miles on it. then he sold the car. i do believe his fastest time on a dry shot was 14.3 and i do no that with me in the car it was 14.4. just think that time will be faster with a wet shot. and alot safer for you and your engine. kerry!!!
