75 Nitrous Shot
it is not has bad as people say it is. you will only blow something if you are stupid when you use it. do your homework before use
it all depends on the users preference. but just look at the sticky in the nitrous section.
I highly recommend a RPM switch too. In fact most of them nowadays have a built in WOT that connects to the TPS (good for drive by wire TB cars). Program the window switch for a minimum and maximum RPM. Preferable at least 3,000 RPM to activate and then 200 RPM below the shift point. Just as an example, if you shift at 6,500, then use 6,300 as the cutoff point. With this set up once the system is armed, you'll spray at WOT and when the RPM is within the window.
Add a fuel pressure safety switch (FPSS) and get the sucker tuned, so you don't run lean. There you have it.
1 bottle just doesn't last long enough on the street or at the track. i thought of a 20lb'r but just 1 10lb tank is heavy as hell getting in and out the trunk.
I run a miroswitch under the pedal and it's wired into my msd digital rpm window switch, the sex. i got mine set for 2700-6200. the digital switch from msd has a 300 rpm fail safe range.
and that fast and furious **** is just plain stupid. go with either a tps or microswitch with a good a window switch if you like your car.
im running a Nitrous Express Hitman EFI on my 2.0... i freakin love it... was just at the track (im a newb driver) and was running low 14's (best was a 14.1).... and im only on a 50 shot
it was said once and i'll say it again Nitrous FTW
man i cant wait to get my kit fully installed. i am doin it little by little when i have time. any videos of 2.2 balts on the jucie? id like to see what my car might do hahaha and no exploding balt vids. you might jinx me
I know I'm not a 2.2 409Cobalt, but im heading back up to the track today and im puttin in my 75 shot jets, last time i managed to go from 14.8 (no spray) to a 14.19 w/ just a 50 shot... im hoping to nab a 13 second pass today if im lucky!! woo woo!
