Can I run Water Methanol Injection With My Nitrous Injection?
Non Authorized / Non-Supporting
Recently here at AIS, two of the most asked questions by inquiring customers has been "Can I use water methanol injection with my nitrous oxide? And if so, what sort of benefits will it offer me?" Because of these inquiries, we decided to dedicate an article specifically for it to help answer and explain some of these common questions we receive concerning the use of water methanol injection with nitrous.
Click on the image below to read the article.
http://www.alcoholinjectionsystems.c...icle_info.html
from the article:
Together, water methanol injection serves to act as a substantial octane enhancer allowing 91-93 octane to perform like 110+ octane fuel.
so in theory, with gms3 on 93octane, could you run the high-octane mode with water/meth? i dont know much about this so someone please correct me if im wrong. thank you
from the article:
Rodney
Here's the link.
nice....so just to get things straight.
most people say its fairly safe to run a 50 shot on the gm stage 2 tune.
so with the addition of water/meth injection, would it be possible to run a 75 shot on the gm stage 2 tune without having to retard timing and change it?
Could you run a wet nitrous system with only water/meth adding the fuel and not running a fuel nozzle at all? I wonder what kind of gains you'd see from a 50shot of nitrous running meth instead of fuel?
By just adding a water meth system alone without retuning for it. No power gains/safety gains yes as this will substantially push the onset of detonation further away. Thereby allowing you to then put the timing back into your tune that you would normally retard for the nitrous.
