cry02?
cry02?
http://www.designengineering.com/pro...sp?m=sp&pid=72
was thinking this or nitrous. looking for gains, but looking for safety with out spending too much. is this effective anyone heard of it?
Injecting it into the intake would do more harm than good. It is purely a cooling mod, you can get anything from fuel cooler to heat exchanger/intercooler spray.
The T/C guys would yield more benefit from it than the S/C guys!
I dont believe that the kit actually comes with any component but you can buy the air intake bulb kit, spray rail, fuel rail cooler thing, etc. Its for whatever application you want it for.
Like it's been said before, don't try spraying it into engine.
It's a great cost-effective method to nitrous with comparable
results for heat exchanger/intercooler use. The only thing I
don't like is that depending on your intake filter sits, I would
suspect that some of the expelled CO2 could get picked up.
The only product I own from these guys is the fuel cooling bar
thing. I'm trying to use it for something other than fuel though.
exchanger sits between the AC condenser and the radiator. The best thing for this to work
is to have the spray bar directly on the heat exchang.
I had at one time removed the AC condenser and mounted the spray bar on the exchanger. Worked good but no AC. I later added a front mount heat exchanger to my system flowing post the stock unit. Then had the spray bar modified to fit the new H.E.
and replaced the AC condenser. If you end up going with one of these systems be sure to pre-freeze at a lower vehicle speed pre-boost or at a complete stop i.e. red light or
staging or might suck co2 in to the intake and that will cause loss of power, think of
a fire extinguisher, or better yet spray NO2.
never had to cool my fuel, and i usually make back to back runs with just a few mins between each run
drive just about every car i've owned down the highway at 90mph for 20-30mins and none of them had overheated, or loss of power due to fuel issues
don't see this as being useful for fuel cooling, anyone have any data or statistics for this?
its like adding another coolant to your car. really cold fuel will keep the combustion chamber and surrounding areas a little bit cooler. Colder fuel is denser fuel as well so you can run "leaner" mixtures safer and make more power (i.e. more fuel bigger the explosion). Think ultra weak N20......at least in principle.
unless the car is under severe heat soak, it should make the exact same whp with the same conditions (dyno car, then drive it down the street and take it up to 100mph, then dyno the car again, bet it makes the same power
i understand the idea..but i dont see it making any real difference i guess
)i understand the idea..but i dont see it making any real difference i guess
)Like they say on their site, they had a 9% gain on a 110hp NA honda by using just the intake bulb. Why? Because colder air is more dense therefore allowing you to run more fuel = more power. Say if its a not summer day and its 85* outside. Your car will think its running on a 35* day because of the colder air.
The intake bulb sits inside your intake. It is sealed so no CO2 goes into the engine. The CO2 passes through the bulb and flash freezes it which then cools down the incoming air. The used CO2 is then directed down and away from the intake using a purge or hose.
i like that idea, that actually makes sense. super cooling the air intake... i'll have to look more into this i guess. thanks vboost
