Help!!
Help!!
I recently installed a Dynotune Nitrous kit. I had a gm mechanic do the install. The Dynotune TPS switch does not learn my car. Is there a different switch out there you guys out there recommend? I have a 2005 cobalt SS
throttle harness from alldata diy and found the proper lead, the nxexpress tps is self
learning, when you have it connected right is shows a sequence of flasing lights to
indicate it's right
thats almost the same as mine, you connect the wire to the tps and then turn the car off and on 3 times to get the NMU in learning mode, then you have to hand operate the TB blade or press the accel, i think it was 7 times. And then the light would turn green and you were all set.
