Help Me Buy A Nitrous Kit!!!
mee 2.... my goal is to be the fastes ls in the midwest.... i want to run 75 shots... wet .. i just havent found a kit that has everything i need
yeah i don't want to **** with the warrnty either espeacilly bc i bought extra one and paying alot for them but i'm going to start looking into it now
how hard is that to install?
you should drill those holes in your hood so the nitrous purge could shoot out, i kno thats what i would do!
N20 - Is it safe
Im sure everyone has seen the video clip where the 2.2(white) back fires and blows the manifold up and other things. if i put a bottle in my car what are the odds that something like that would happen. What should i do to prepare my car for a 50 or 75 shot.
you cant realy stop it from happening. there is a 2.4 manifold that you can swop over to that is one molded piece. the stock 2.2 mani is two pieces that are glued together. so IF it does happen it there is a better chance things wont turn out so bad for your car.
yes you can prevent it from happening, its called don't spray off the line
or pray that you don't have a faulty setup with a window switch that dies
every 2.2 with a nitrous backfire that I have seen has blown more than an intake mani so switching to a different one isn't gonna do much or anything for you.
I spray starting right when I hit second. First would be stupid, I spin all through first anyway if I just floor it. Second, when the nitrous comes on, the torque hit almost breaks the tires loose sometimes, but its managable. Torque steer is pretty severe though.
Sep 28, 2015 12:51 PM
your like my brother, but yellow.
