might be a dumb question
Original Hayden Fanatic
purge kits, to keep air out of the lines... you can buy a purge kit that is for show that uses CO2 instead of N2O.. much cheaper if all you want is show. Google purge kits im sure ull find something you like.
Colored N2O? Interesting, and I don't see the point (plus any additive would probably mess the stuff up). As for being able to shoot it out your windshield squirters, the sides of the car, or your butt, for that matter, it's the purge valve. The theory originally was that once you arm the system, you hit the purge valve to make sure the lines are full of N2O. Then when the solenoid activates, there's no lag. Truth is, the lag between the solenoid firing and the nitrous hitting the injector has to be like miliseconds with the pressure that stuff is under, so it's really all for show. And it's a waste of perfectly good N2O.
Wouldn't you rather have them think your car is stock instead of showing your hand in advance?
It's N2O, nitrous oxide or nitrous, not NOS or nos (you've been watching the Fast and the Furious again, right?). NOS is a brand name for a nitrous system.
BTW you can't color nitrous oxide.. dont know about C02 though.
yeah you can purge out of anywahere as long as you have a kit. the coloring like you see in midnight club racer or whatever is only acheivable by leds it's like a light on the end of your purge tube that comes on when you purge it.
think of it like when you shin a laser pointer through a smokey room you can see the beam same concept the light bounces off the nitrouse particals and viola colors.
I am not impressed by coloerd nitrouse purges!
as said, it's all in lighting. ZEX makes one as does maybe one other company, but if you wanted you could basically take a cluster of LED's and aim them to backlight the area where the nitrous exits the purge lead. if this is your only need, just use co2 as it's the same color and much cheaper than n2o will be per pound.
http://www.compperformancegroupstore...&Store_Code=ZX
this is a link to the zex led purge kit....im sure there are other places that make them..but its a start.
most people use it strictly to flex before walking someone, and some just use it to imitate. for most shots anyone on this board is running, you can just spray when you shake off your street tires, or heat up your track tires, and get the same effect.
pretty sure that's a coherent statement, thanks lol
clearing out the broken down n2o in the line keeps the car from bogging down when you first begin to spray. while on these FWD cars it's not really going to be noticed as much since wheelspin is a reality to deal with, you will see that good drivers who know how to pedal out of the whole will lose up to a few tenths from just that. you purge that out and you don't have that instant bogging and loss of power. it also would make a difference from a roll too on say a highway pull or mid-stretch on a decent straight in a road course.
well like I said, it is useful, BUT you don't need it in most cases. I dont use it at the track since I have to heat up my tires before a run, so it is fine then. I have used it on courses and highways though to get rid of the dead line area.
anyone who has it will tell you though, it's basically used to get attention on a street car. I have mine mounted where you really don't see it, and it still catches eyes because that sound is fairly specific lol.
Hey, I never claimed to know EVERYTHING! So I have been mis-informed by the nitrous racers I've been around. However, if it were mine, I'd mount the purge somewhere un-noticable. I do appreciate shooting it into the engine compartment might not be the best of ideas, though
honestly though, I don't feel there's enough fuel to wash out the cylinders unless the bottle was totally off (I figured thats what you're hinting at). if it was a 150shot or so direct port, yeah, that would be bad for sure, but these guys aren't looking at running something like that (and the ones that are already know better). the only time I ever had mine die on me was when someone closed my bottle without telling me. I lucked out and didn't damage anything but a few melted sensors. it could go sour quick though with a larger shot.
