Nitrous Oxide N20
nitroud help
Old Jun 13, 2008 | 09:47 PM
UNION30's Avatar
nitroud help
i turned my bottle on today and when i did the nitrous started to flow into my intake so i turned it off whats up with that is a solenoid stuck or what
Old Jun 13, 2008 | 10:27 PM
lil_kano's Avatar
what kit do you have? might be an electrical issue.
Old Jun 13, 2008 | 10:38 PM
hungryhip-ccp's Avatar
hope you waited a while or pulled the coil wire and cranked it before you started it...
Old Jun 13, 2008 | 11:38 PM
xxshadowxx's Avatar
this is obviously a wiring/installation issue. with botle closed check to make sure solenoid is opening/closing on command with switch. You most likely have wiring done wrong or the incorrect solenoid
Old Jun 13, 2008 | 11:41 PM
JohnsRallyYellowSS's Avatar
Or the solenoid(s) are hooked up backwards. Make sure the IN and OUT are in the respective areas.
Old Jun 13, 2008 | 11:46 PM
xxshadowxx's Avatar
a solenoid should be a power on or off situation. power on + open power off = closed. If it were wired incorrectly, for example wires were switched, the outcome would result in the same action.
Old Jun 14, 2008 | 01:11 AM
yellowltcoupe22's Avatar
sounds to me like the soleniod is stuck open. keep the bottle off and try to make the soleniod activate and bump it with somethin to try and free it up.
Stouffer
Sep 10, 2008 05:59 PM
