Nitrous or Meth
Nitrous or Meth
What would be better to run with my car.....the zex nitrous kit from cobaltperformanceparts.com or run meth....and whats the best place to get the meth kit from....any advice is appreciated..Thanks!
NAWS DUDE!!! jk, meth is more useful because in the future when your running a hot setup ie 2.5" pulley you can have meth set up and still run a race gas tune w/o the race gas since it boosts your ocante and lowers temps and stops detonation
are you taking water meth or straight meth. Water meth is good for about 15 whp while straight meth if tuned properly is 35 whp at aprox 18 psi of boost. Most kits you see can't run straight meth. If doing water meth get the devels own kit if doing straight meth cost about double go with this
http://www.alkycontrol.com/
You don't need to keep chainging your tune just keep the bottle full.If you are worried about it just get a manual boost control so you can turn down your boost.
you mix it up... there are two kinds of kits the front mount kit that uses your windshield washer fluid tank and the rear mount which has its own tank. i prefer the front mount kit cause the car tells you when your low on washer fluid, the tank out back doesnt. both are very effective
really roll over let me know how that goes im gonna get that trunk mount kit from alcohol injection systems off ebay i know one of my friends got it and it works really good but i might end up doing nitrous too ....let me know how that works!
later
Get this kit talk to Chance great guy to deal with.
http://www.alcohol-injection.com/wat...e-kit-106.html
