Nitrous On The New Ss/tc
choko is the guy u want to PM but he will tell u the same thing i am now, u MUST tune for your nitrous if you plan on gaining any peak power with it, he is the guy who blew his motor and he did so to test it's limits before building it up, he will be puttin down some powerful 1/4 mile times come summer.
if u ran a wet kit on it itd be fine I'd have to T into the fuel like before the rail due to direct injection going from 58psi to 1000 my buddy back home in Michigan is thinking about running spray I personally recomend it just always run a richer fuel jet then needed fouling a spark plug is 8$ melting pistons is a lil more ha
That's probably because dry kits run more lean than wet kits, running lean is usually more powerful but also a lot more dangerous.
Stay away from nitrous on a DI motor.......That is just my opinion, no need to look into it more and find out that it really isnt a good idea. Lol. If you do spray it, run a 50 dry shot with a tune, i think you would be fine.
The only thing about a wet shot on a DI engine is the engine uses minute fuel to run and when you put the wet shot on you are dumping allot more fuel into the cylinder because it gets it from your fuel port. I was going to do it to mine had the kit and everything in my room but I didnt think it would be safe to put that much fuel into an engine that uses droplets of fuel to run. So I sold the nitrous
I also got on the mazda forums and asked the speed guys and the ansewr I kept getting about nitrous on a DI engine was to many zoom zoom boom sotries, If you were to do any nitrous I would do a dry shot and tune it to get the extra fuel from your injectors, you would run richer normally but probably not much.
I am interested in this as well. I am pretty new to nitrous, I know the basics, like wet vs dry, and what N20 basically does.
Now, reading this I had an idea. Running a dry shot, like a 50 shot, could we tune the 90-100% load tables rich, so the nitrous doesn't make us lean? I mean, I wouldn't run my tune pig rich on the street, but only when I was going to shoot. I could tune the map so it gets rich at the RPM the nitrous would start shooting.
Any ideas? this is just a thought thus far, and i haven't had time to think it through yet, so let me know what you guys think!
My friend was running nitrous on his SS/TC https://www.cobaltss.net/forums/pictures-videos-64/my-ss-tc-action-some-v8-buddies-146312/
I got to thinking about it more and more at work tonight, that i could likely run a 50-75 dry shot fairly easily. The only problem would be the fuel injection window. I think we have about 7ms to inject fuel, and I think I am near 6 or 7 already. This would mean that I could not run as rich as I think I would need to and still keep it safe. If/When we get fuel pressure unlocked in our tuning tables, I know I will be able to tune for it.
See, I was thinking I could run a window switch, and start shooting about 3k rpms, just so I didn't lose all traction, and just tune it pig rich from 3k up at 90-100% load.
I will still ponder this, and possibly, if I can find a good cheap dry shot kit pick one up. Anyone know of any used kits?
Yes, but I could reflash when i was not intending to shoot. I would never run it on the street, therefore no need to have that tune. And, when I was shooting, I would be going down the track. Idling around at the track, I could tune to run at stoich. IDK, it was just a thought, mainly considering the way the fuel would be sprayed. DI is so fine of a particle, and this would be a much denser spray, like someone had mentioned earlier, so I was trying to figure out a way around it.
Odds are, second gear is gonna be close to worthless at the track unless you are running DR's or better, so you will really only get to spray through most of 3rd. On the street is where the powerband can really shine on these cars.
The main advantage of the finer DI injection is cleaner burn in easy driving for lower emissions. The evaporative cooling from the fuel going directly into the chamber helps with power output, since it helps control chamber heat and reduce the engines tendency to detonate, but thats about it. Mostly an emissions thing.
**** that, why not use it on the street?
And why spray on the street? I don't really street race, and if I was, I would be able to reflash in less than 30 seconds. I am not going to drive around with a charged nitrous system at all times. Not only is it dangerous, it is a waste of N2O, because the system will lose pressure eventually.
As for the DI being mostly an emissions thing, I agree. But our engines are so closely monitored for emissions, I am afraid that the extra fuel coming from anywhere BUT the injectors would cause a problem.
