Opinion-How much time does a 75 wet shot take off the 1/4 mile
this cannot be answered by anyone because they dont know ur driving skills..u may spray the nawz then start spinning and suck at driving and u end up with a worse et then u did before the nawz
^^x2 man that's wayyy more than I thought it'd take off. If it really is 2-3 seconds, that's worth looking into now. I always held off before because I don't want to blow my car/engine up.
its not going to be that big of a difference if you're already running 13.5's as the power levels required to go faster increase as your times get lower obviously.
those responses are from cars that run 16s stock
think of it this way.. what percent of your total hp is 75 hp... the less of a % the less difference it'll make
Are you talking about a stock or tuned engine???? taking 2 - 3 seconds off your quarter time sounds fishy, but I guess my previous question will bring more clarity for me. How about you spray your car, and tell me how the ecu reacts
hahahaha, 10.5 with a cobalt by adding nitrous!?!?! if you believe that you then you shouldn't be messing with the stuff. if you're running 13.5 already, then a 75 shot (it ur engine can handle it), even with all the accesories and sprayed at the right rpm band, you would still be in the 13s, maaaaaybe a 12.9X
Much misinformation in here...
Stock 2.2 balt will see pretty big gains, over a second I would think, as you are adding nearly 50% more power to the car. LSJs are not going to gain that much, but a solid .4-6 seconds is def possible, assuming the car holds traction in second gear. Individual results will vary, and as the car gets more mods and quicker, the amount of increase from the nitrous goes down. I'm assuming almost totally stock cars for my numbers.
