Nitrous Oxide N20
running lines
Old Nov 26, 2008 | 01:44 AM
mmcgee123's Avatar
running lines
where and how do most ppl run there lines from the bottle to the engine bay i hear its a bitch tryin to get it thru the fire wall
Old Nov 26, 2008 | 01:57 AM
EmperorJJ1's Avatar
actually the balt has a nice big grommet to run stuff thru (or that you can really)
Old Nov 26, 2008 | 06:49 PM
SSdan's Avatar
Yep.
I ran mine through the grommet that is right behind the pedals, under the carpeting along the side behind the rear panel and right into the trunk. Worked perfectly.
Old Nov 26, 2008 | 08:16 PM
yellowltcoupe22's Avatar
i ran mine through the hole in the bottom of the spare tire spot around the gas tank and into the square bracing under the car, it comes out at the engine bay.
Old Nov 26, 2008 | 08:18 PM
originaladrian's Avatar
the firewall hole is perfect
Old Nov 27, 2008 | 01:35 PM
IonNinja's Avatar
i drilled a hole and ran mine through the passenger side firewall...should've used the grommet. gets a little cramped though when you have all your wires going through it though.
Old Nov 27, 2008 | 03:52 PM
REDFOCZ's Avatar
What no pictures?
Im sure some of you took install pictures of this
Old Feb 25, 2009 | 12:05 AM
Lants's Avatar
I went through hole in the trunk and followed the frame rail. Gave me plenty of play for the set up in the engine compartment on the passenger side. plus really didnt want a nitrous line under my feet.
Old Feb 25, 2009 | 01:23 AM
EmperorJJ1's Avatar
did you snap any pics? i need to do the same soon but id prefer to do it on a lift which i dont have
Old Feb 26, 2009 | 10:24 PM
Lants's Avatar
i'll get some pics soon, but you dont need a lift its pretty simple. but i am changing how mine is routed i did it in a rush. im going to drill a hole in the front of the trunk avoiding putting a hole in the fuel tank and run it on the inside of the frame rail. this way to avoid it getting pinched in a wreck if i were to have one and there is threads in the side of the vavle cover im going to use for a bracket for it. and i think im going to move the bottle to the back of the back sit with it folded down. so i can open and close the bottle until i get a remote. cause when something goes wrong it sucks stopping and running around to the trunk
Old Feb 26, 2009 | 10:26 PM
ilovecars's Avatar
yea pics of said grommet would be awesome
Old Feb 27, 2009 | 02:56 AM
EmperorJJ1's Avatar
sweet. ya i dont need to do that seeing as im running a ground wire not nitrous lines. so in a wreck it will just ground better lol
Old Feb 28, 2009 | 12:57 AM
Lants's Avatar
tried to take pics today but my camera wouldnt stay on, battery screwed. speaker wire doesnt need to go under the car. just look how the battery cable is routed just do the same on the other side, you can do that with nitrous line to but going under the car took me no longer than 15 minutes, but i did use a jack and battery cordless drill, becareful to keep it off the rack and pinion and cv axcel.
DarrenGC
Dec 24, 2021 01:55 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
dieGone
Oct 1, 2015 06:27 PM
SlowSaturn
Sep 28, 2015 11:03 AM
