Nitrous Oxide N20
are these the right plugs?
Old Apr 24, 2007 | 06:02 PM
widebody_balt_ss's Avatar
i have read through the posts and see people go back and forth with numbers and just wanna be sure. ngk plugs Bkr7e- this will be with a 55-70 shot of n2o, not sure which yet.
Old Apr 24, 2007 | 06:11 PM
intense_SS's Avatar
get the zex plugs man they are way better than those!
Old Apr 24, 2007 | 06:17 PM
Kaisoboy's Avatar
Zex FTW!!! Part# 82003-4
Old Apr 24, 2007 | 10:22 PM
IonNinja's Avatar
yes those are the correct plugs
you also have the option of Autolite 3922's
Old Apr 27, 2007 | 04:18 PM
06Pursuit's Avatar
whats a good gap for 75 shot ionninja?
Old Apr 27, 2007 | 04:33 PM
slowion2's Avatar
lol they do the same thing but are more expensive
.035 should be fine. you can start at .040 and gap it down if there is any blow-out/miss present.
Old Apr 27, 2007 | 04:36 PM
06Pursuit's Avatar
i think i'll start with 35 lol any kinda missing isn't good lol. thx slowion
Old Apr 28, 2007 | 01:51 PM
06Pursuit's Avatar
hey i just changed the plugs to the 3922's. I noticed a power loss when running the premium fuel but I also noticed a benift. Has anyone else had the 2 steps cold plugs get rid of the idle surge? Mines gone, I just noticed it now. just thought id add that
Old Apr 28, 2007 | 03:14 PM
IonNinja's Avatar
my gas mileage appears to go down sometimes too...I figured it was a combination of 91 octane and colder plugs but its necessary to run nitrous safely so I deal.
Still going atleast 250 miles before I get to 1/4 tank or slightly below so not that much of a biggie.
Old Apr 28, 2007 | 04:05 PM
i bought the zex plugs and a 55 shot of n20. Holly ****! the car ran great. i drove it 2 hours home after the track and it seems to idle and run alot better. I would reccomend the zex plugs even without running n20. now this is only after 1 night and day but, seem to be good plugs
Old Apr 28, 2007 | 05:53 PM
slowion2's Avatar
haha I have a nice lopey idle but thats for different reasons all together
Old Apr 28, 2007 | 08:03 PM
^^^--lol i love thant window licker thing,....gets me every time
Old Apr 28, 2007 | 10:26 PM
06Pursuit's Avatar
has any one tried just using the jet as an extra injector? Running just fuel and no nitrous?
Old Apr 28, 2007 | 10:33 PM
slowion2's Avatar
it isn't going to disburse like you're thinking, the main reason that it does is because of the nitrous exiting at a high pressure and fanning out, so it mixes with the fuel then. if you ran just fuel it would just be a stream type dealy if not a series of long drips. boost wouldn't like it. look at how small the pintle of an injector is, then look at the fogger design, thats the difference/reason.
good to see someone thinking out side the box though
Old Apr 28, 2007 | 10:36 PM
06Pursuit's Avatar
well i thought id ask any way. thx for the input!
Old May 3, 2007 | 12:47 AM
turbo06ss's Avatar
I tried it one day at the track and it ran about a tenth slower. I also found that my car pulled harder with the plugs gapped at 28, but then again I blew my **** up.
Old May 3, 2007 | 12:50 AM
Red2.4SS/SC's Avatar
those are not the right plugs you need ngk bkr8eix's
Old May 3, 2007 | 01:03 AM
turbo06ss's Avatar
I put around 20 to 25 bottles threw my car before it blew up and used the ngk bkr7e. The only reason my car blew up was , I finally got the damn thing to hook and it bogged down and went boom.
Old May 3, 2007 | 11:24 AM
slowion2's Avatar
what was your bottle pressure? if it pulled better with .028 you might have had blowout, but I'd venture to guess your bottle pressure was a bit too high if you got blowout past .030 on a stock build.
for a 2.2 those are 3 step colder, 5's are stock heat range. it also isn't super necessity to run iridium either, which those are. thanks for the concern though, it's nice to see people at least concerned and recommending to go colder than tell someone to run stock plugs and detonate at the strip.
I'm going to see if the stock 2.2 and 2.4 plugs are the same range. if they are then those are 3 steps colder for the 2.4 also. if not I'll put up which ones are which.
Old May 3, 2007 | 03:51 PM
06Pursuit's Avatar
hey i was dickin around and ran the 65 shot on regular with the autolites and no detonation....... prolly wont do it too much though lol espesualy on the 75 shot
Old May 3, 2007 | 04:00 PM
Chris_Leslie's Avatar
Is there any good plugs that would help performance on a 2.2 with CAI????
Old May 3, 2007 | 05:13 PM
slowion2's Avatar
haha stock gapped down maybe, I know of a few guys running stock heat range copper plugs (ngk 5's) gapped down to .035 or .040 that like them a lot
Old May 4, 2007 | 12:16 PM
turbo06ss's Avatar
I always run the bottle between 975-1050. after the purge it sits at about 1000. I also was on a new bottle and I put 12 pounds in a 10 pound bottle. That makes it a little lean coming out.
Old May 4, 2007 | 12:20 PM
slowion2's Avatar
eh a little but not a whole lot, sounds more like it reacted like a timing advance from being gapped so far down but I don't know that doesn't seem right.. I've put 12lbs in and run 900-1100psi without a problem, but I also am running a size larger fuel jet for safety and a few other reasons.
Old May 4, 2007 | 01:13 PM
turbo06ss's Avatar
I was running a 20 jet instead on the 24 and when I poped the motor I put back the 24 jet. I also had 8 inch lines to. It it hard as hell with those short lines.
