View Poll Results: Do you have nitrous?
2.0 SS/SC sprayed and blown
22
12.43%
2.4 SS Yup im sprayed
1.69%
2.2 LS/LT Yea I spray
14
7.91%
I plan on spraying my car.
80
45.20%
Spray is for idiots
58
32.77%
Voters: 177. You may not vote on this poll
Who has Nitrous?
Nitrous is wicked.The only problem is that it is addictive. Once you spray you don't want to drive around off spray. Up here it costs $100 to fill a bottle. As for dry or wet I am a bit leary of running a wet kit on the sc cars with the way the intercooler is I think it might seperate the fuel and poss lean out. I have a direct port kit waiting for install but I can't seem to figure out where to put the nozzles. So if anyone is running a direct port system on there 2.0 car please pm me.
I plan on putting a 50 shot on my car before the end of December hopefully, I've got all the **** next to me, I've just got to get my clutch in.
I run nitrous, its alright but now I want booooooooooooosssSSSSSTTT!
I had it on the Cobalt, but sold it before I actually hooked up the switch and filled the tank. Why I don't know. Was scared of going boom. I do plan on running a 50 shot when I upgrade turbos to help with lag.
I'm not even sure how you would control the amt. of fuel being dumped by the injectors on/off the spray unless you just had two completely seperate tunes you'd have to load in HPT.
Nitrous is a must i'm really glad i got it everything is still fine im only sprayin the 50shot im scared the internals are pretty much maxes out i should be around 320whp on spray considering my dyno was 268 whp.. I also got my purge rigged up today ***** sicks i didnt mess with it for the longest time i kinda forgot about it.. cold weather and nitrous is freakin insane no traction at 60 haha
I spray, I Go Fast, I love.
you guys that are worried about going lean on air fuel when spraying ever consider using meth/water injection with it? It boosts your octane a ton, it is pretty much impossible to go lean while using it,. that means BIGGER SHOT! im going to be going from a 75 shot to a 100 shot if the dyno tuner gives the ok.
I would also like to know your mods.
Last edited by widebody_balt_ss; Dec 4, 2007 at 10:08 PM. Reason: Automerged Doublepost
they were in my sig but they like decreased the size
Zex Wet Shot Nitrous- Exedy Hyper Single Siemens 60 lb injectors - PB's 2.8 pulley
Pacesetter ceramic coat header (not installed 4sale)- 3"zzp catless dp-cobra h/e
Injen Intake-GMPP exhaust- Hp tuned - -Progress Springs
Ingalls ETD- 5% tint - NGK BK7RE's- 2 12" kicker Comp Cvr's
I cant wait to see my dyno then^^^. seriously. il have a 2.7 and meth injection, lightweight flywheel and stage 3 clutch,and a ported blower. I was hoping for close or right at 300 before spray, then a 100 shot! I might be close! we have very similer mods....
can i get a sound clip of ur car plz?? the 3 in. catless and the gmpp exhaust is wut i wanna go
and yes i have nitrous, and for ppl that say it is fake power, they will never go fast
o and for whoever said its 100 bucks to filll there bottle there u better go hit them in the mouth
cost me $25.61 to fill the entire 10 lb bottle
Wait, just realised it was you Chris. You've heard my car, you know what it sounds like.
Last edited by ItalianJoe1; Dec 4, 2007 at 10:41 PM. Reason: Automerged Doublepost
Short, 1-2 pull
http://www.youtube.com/watch?v=PHpidOAYMiU
Yeah, I noticed the other day that there's like 3000 views on that one. I guess people do watch it, but nobody comments or says anything. I still challenge any LSJ in south FL to run me. I don't think that I'll beat a turbo one, but I'll be damned if one on the blower pulls me.
Last edited by ItalianJoe1; Dec 4, 2007 at 10:46 PM. Reason: Automerged Doublepost
Its cool to run people, and I don't care if I lose, so I always have fun. But, there are 1200hp street cars here, and no matter what you do, there's always someone faster. Makes me worry that even with 400+hp when I finish the Balt, I'll still be stuck in the middle.
I run a 2 stage nitrous set up. Stage 1 is 3,000rpms to 6,000 rpms 50hp dry shot controlled by a window switch. Stage 2 is 4,200rpms to 6,000rpms 50hp dry and 75hp wet at the same time for 125hp.
the car is in stage 2 from second gear on, here are some pictures of my set up.
50hp dry shot here
75hp wet shot here
window switch here
nitrous bottle here
50hp dry shot here
75hp wet shot here
window switch here
nitrous bottle here
