Who is planning on...
...running a nitrous setup on their Cobalt? Wet or dry? What size jets? And anything extra fancy? I'd be curious to see how popular an idea it'd be for forum members. I don't know how many RL owners have put nitrous systems on their engine, but with the setup..it seems like a possibly easy and cheap way to get some more ponies.
I know a fellow alero owner that's is gong to be going with alcohol injection on his supercharged 3.4
http://www.alkycontrol.com/
I don't know who he's looking to go through but there are a bunch of different vendors. Its' supposed to be very safe and reliable.
Depends how hard the tuning bug bites me. I'm sure if I take it to the track I'll be tuning like mad.I can't even stand my car on topshift.com standing still and not gaining a 10th here or a 10th there....
sup
as soon as i get SS my NX kit will be on it. its a wet kit. never spray dry nitrous is only bad if ya dont know what you are doing and i will spray about a 50 shot i has it on my ss camaro with a 175 shot did fine and the car still runs good and i had it on my 2002 malibu ls and ran 13.9s@ 101mph and that was on a 100 shot and had 150 shot in the but ran slower cuz of traction issues here at hawaii track i get 2.4 60 ft on motor running 15.5 in the 1/4
Well I hate dragging up old topics but Im new.
I would highly recommend using an alcohol injection kit on any force inducted car, this will help a lot to keep detonation from occurring with the right tuning.
Yes, NOS is only bad if u don't know what ur doin
I ran a 75 Dry shot on my old car, and never had problems. and i was a freekin Button Junkie
I went thru a bottle of nitrous every 5-7 days
Nitrous is VERY fun, but u just gotta know what to look for, and know ur car inside and out
I do plan to maybe run nitrous thru the SS, but not a horribly large shot.
I've arreddy done nitrous, time for sumpin new, I wanna play with boost
lol
well i have been messin with nitrous for about 8 years now and i have never hurt a motor with it ! The key to that is never used a dry kit always us a wet kit! and always no what to do with your timming and fuel. lol this is from someone who sprays a 175 shot on a ss Camaro and a 125 shot on a 2002 v6 malibu and had a 150 shot in it once b4
and a 300 shot on a 72 ss nova!
Don't know if this will help, but we were talking about it down at the RL Forums.
http://www.******************/forums/...ead.php?t=1322
I was thinking the NOS sportsman fogger setup that you can plumb right into the intake manifold. You couldn't slip it past the dealer however. I wonder if they would note a mod like that for your car/vin even if you were just in their for an oil change.
I guess I will have to wait and see what Chevy comes out with for performance parts.
I run a NX wet 75shot of nitrous through my little 2.2ohv right now and wouldn't hesitate to install it on an SS! I wouldn't run it over 50 though! Basically I'd want it to cool off the charger since they're known for heat soak, plus I can get more boost out of the charger while its running cooler and get the shot of nitrous at the same time!
1 Use a wet kit
2.Get colder plugs (NGK Tr6 or Tr71x)
3.Install correctly
4.Use proper jetting advised by the online NX jetting calculator
5.Use Wide Open Throttle switch provided with kit
6.And don't over-use it and you should be fine!
1 Use a wet kit
3.Install correctly
Since the throttle is electronically controlled your going to need a system that can use the throttle position sensor. I think NX makes a gadget for 99 bux that lets you use the TPS voltage
I think that along with a window and fuel presure switch will be pretty safe.
I am looking at a "Fogger" system that will have the wet nozzle put into the intake manifold.
I gotta wait for a while before I drill into the intake manifold and void a good portion of my warrenty.
Originally Posted by brianfcp
i'd go with nitrous if it didnt void the engine warr.
You could do a dry shot and chances are you could remove it if you brought it in for services and no one would notice....
A wet system is going to require some more extensive mods like tapping a fuel source from the fuel rail.
A dry system isn't as bad as everyone makes it out to be. A lot of ricers run around with big dry shots and don't have the fuel system to back it up. If you do run a dry shot you have to have a good intank and inline fuel pump and properly sized injectors and tuning.But I for one would be worried about running nitrous through the compressors in the Supercharger.
