CT Cobalts
#4332
I dont think my intercooler is working properly...fluid is running through it and the hosing is deff all hooked up correct, but im still running normal temp. and when i drain the fluid it not hot...any ideas?
#4334
turn the car into on position and check your filler neck, is the fluid bubbling?or if you have option b it should be doing the same in the tank, if not IC pump is dead, if it is, are you talking about normal temps ideling or at or after WOT?
#4335
fluid doesnt bubble..i have a stock fill neck..after WOT im running 180ish give or take...but when i idle at one point it got up to 220..not good
#4337
my car stayed around 180 now its 190 to 200 i have been wanting to check my coolant level. i took the stupid cover off the motor to let some of the heat out. its also been so hot outside im guessing that is also why its running hotter.
#4339
Saw an SS/SC today. It was at Misquamicut beach in Westerly, RI, but it had CT plates. It was silver, had a black/cf hood (couldn't tell) with a hood scoop, had exhaust, they moved the "COBALT" badge to the middle of the trunk and the SS badge was under the left reverse light and it was CF. Any idea who it is?
#4341
#4345
#4349
