North Pacific WA and OR
brians go fast build
Old Dec 22, 2010 | 01:46 PM
blk06cbltss's Avatar
ok so tax time is coming and i wanna see if i can get over 300whp with the m62. let me know what else i could use or do thats cheaper.
the wants
cams
valve springs
p&p blower/tb(maybe the head too)
2.7 pulley
8k redline
vince dynotune
working on getting the e85 on post
60lb injectors
3" dp and 3" exhaust
0r
tvs
vince dyno tune
Old Dec 22, 2010 | 02:06 PM
hawlyns711's Avatar
I like how the first setup is looking.
Old Dec 22, 2010 | 02:09 PM
me too and it will be cheaper then a tvs+tune. but then the tvs can get me to the high 300s after afgan
Old Dec 22, 2010 | 02:13 PM
hawlyns711's Avatar
you should check out my build thread on RLF...
rebuilding the lsj - Saturn ION RedLine Forums
I did pretty much your first setup with a few miscellaneous things squeezed in there too, long thread but worth the read in your case, just finished last week!
Old Dec 22, 2010 | 02:15 PM
a guy on the rlf is selling gmr cams for 250$ im deffinatly wanting them
Old Dec 22, 2010 | 02:17 PM
dope
Old Dec 22, 2010 | 02:18 PM
Old Dec 22, 2010 | 02:21 PM
hawlyns711's Avatar
the problem with that is you're going to have to change some other not so common valve train components to run those things. It's been discussed how the cams have a smaller base circle so the angle they sit and push against the rocker rollers is affected, in a bad way. solid lifters or different rockers is what you will get into when you do that. I suggest looking at the zzp cams (the ones I have) but they're also 3x as much as you could get those gmr cams I'm seeing...
Old Dec 22, 2010 | 02:22 PM
haha photoshopped? and im wanting to have mine powdercoated white or orange lol.
Originally Posted by hawlyns711
the problem with that is you're going to have to change some other not so common valve train components to run those things. It's been discussed how the cams have a smaller base circle so the angle they sit and push against the rocker rollers is affected, in a bad way. solid lifters or different rockers is what you will get into when you do that. I suggest looking at the zzp came (the ones I have) but they're also 3x as much as you could get those gmr cams I'm seeing...
**** that i dont wanna build the whole motor lol i wanna stick to the minor things
Last edited by blk06cbltss; Dec 22, 2010 at 02:22 PM. Reason: Automerged Doublepost
hawlyns711's Avatar
well if you have any questions besides asking on here just pm me I was just doing this not too long ago
Old Dec 22, 2010 | 02:23 PM
alright i will if the washington homos cant help me out.
Old Dec 22, 2010 | 02:24 PM
nah its real haha yea white sounds sexy, ill probably do mine that red and even keep the red pinstripe...i did in the pic but thats fake
PS CS5 coilovers for the drop haha
Old Dec 22, 2010 | 02:25 PM
yeah the drop looks sexy. do you know how much our rims weigh? i know they are pretty damn light compared to the stockers
Old Dec 22, 2010 | 03:00 PM
Phyrric's Avatar
the wants
cams
valve springs
2.7 pulley
8k redline
vince dynotune
60lb injectors
tvs
fixed
Old Dec 22, 2010 | 03:19 PM
haha yeah im going tvs after afgan no matter what lol. ill be living in montana(e85 everywhere) and tvs+e85=beast
Old Dec 22, 2010 | 08:43 PM
i think they weight the same as the stock rims but they are wider so they are lighter in the sense of size haah
stock 18x7 our rims 18x8 about 22-23lbs
Old Dec 22, 2010 | 08:44 PM
my rims with a tire is lighter then a stock ss/sc rim without a tire lol
Old Dec 22, 2010 | 08:49 PM
Supercharged Guy's Avatar
Everything in the 1st section + the TVS
You can't go wrong, I mean yeah the TVS is expensive but well worth it
Old Dec 22, 2010 | 10:54 PM
yeah i wish i had the money to do that right now but its either one
Old Dec 22, 2010 | 11:17 PM
hahaaha tire rack says they are 23lbs
the stock rims are heavy tho haha
Old Dec 22, 2010 | 11:19 PM
oh well what offset are they?
Old Dec 22, 2010 | 11:42 PM
+42, i think for a while i been saying +45....i was informing the lst few people i talked to hahaaha
Old Dec 22, 2010 | 11:54 PM
damn i thought it was 40 or less they sit pretty flush. i wanna get +38
Old Dec 23, 2010 | 12:01 AM
yea the front needs some poke to get flush and the rear is nice
im thinking of running a small hub spacer to give it that aggressive stance
that would be sex, if these rims had a more aggressive offset like u said +38 they would clear brembos (big boy brakes) and look dope er haha
Old Dec 23, 2010 | 12:07 AM
yeah im very close to getting a small spacer so i can get a sexy stance.
