For Sale Brembos, Suspension, LSJ Intake, Cluster, Body pieces, and more
Old Mar 24, 2014 | 09:03 PM
sc4door's Avatar
Means of contact: PM, email (colvingarrett@yahoo(dot)com), or text (seven 4 zero-27 five-two four 3 two)
Just made a new thread because I wasn't able to edit my post in the last thread so this was the easiest way to show what I have left. If I need to get updated pictures, I can. Just figured they weren't too old yet.
Stock sedan lowrise spoiler. Came off my SRTC 09 LNF sedan. $50
Brand new SS sedan rear bumper. Only has primer on it right now. $200
LNF Gauge cluster. $95
The following brake parts were literally used less than 24 hours before my car got wrecked so they are all basically brand new.
LSJ rear calipers, brackets and pads. $225
LSJ rear rotors. Holes have been machined out slightly to accommodate a 5x114.3 bolt pattern. Will work with stock (5x110) bolt patter still as well. The discoloring on the rotors is simply because the pads had just begun to bed in with the rotors. This is not a problem, this is a good thing. $50 for both
Brand new LNF front rotors. Same thing as the LSJ rears, the holes have been machined to accommodate a 5x114.3 bolt pattern as well as stock. SOLD
Stock sedan tail lights $25 each
Slate blue power mirrors $30 each
ZZP 3in. LSJ intake. Hydroshield is already sold. Filter is slightly bent but completely usable. The coupler has 2 holes cut in it that I used for meth nozzles so if unless you plan to mount meth nozzles there, you'll need a new one ($17 from ZZP). SOLD
Stock LNF shocks, struts, and springs. Have an extra shock laying around with low miles that I'll just send with the rest of the shocks and struts. These came off my current car at about 63k miles. One strut is assembled, the other has a broken stud on the top hat so I took it off (don't let idiot friends help you swap suspension when they don't know how to use a socket set lol) $300
Magnaflow 2.25in exhaust $300
LSJ washer bottle $15
Brembo calipers. Need rebuilt which I will be doing in the near future. If someone wants them as is to rebuild on their own, I'm open to offers. If I rebuild them I'd like to get $400. Comes with pin kits, clips, and hoses.
Old Mar 24, 2014 | 10:18 PM
eutechnyx's Avatar
trustworthy seller, my brake stuff was shipped next day after payment and arrived as described. glws
Old Mar 24, 2014 | 10:46 PM
Is there any difference between LSJ and LNF rear calipers?
Old Mar 24, 2014 | 10:49 PM
taintedred07's Avatar
Lol I was wondering the exact same thing!
Old Mar 24, 2014 | 10:50 PM
andrewcarr1993's Avatar
Yes
Old Mar 25, 2014 | 04:31 AM
Corey V's Avatar
Ill give you 175 for the brembos
Old Mar 25, 2014 | 06:27 AM
sc4door's Avatar
Thanks for the sale and the feedback!
Yes. LNF rear calipers suck and LSJ's seem to work ok lol. But seriously, LNF calipers don't have a separate slider pin like most calipers, it's designed so that the bolt the holds them on is also the slider. Pads and rotors are different too.
I'll pm you
Old Mar 25, 2014 | 06:45 AM
street253's Avatar
I'll pm you
I wouldn't do business with coreyv.he is a scammer
Old Mar 25, 2014 | 07:30 AM
sc4door's Avatar
Thanks for the heads up
Old Mar 25, 2014 | 08:53 AM
sc4door's Avatar
LNF front rotors sold
Old Mar 25, 2014 | 01:59 PM
sc4door's Avatar
ZZP intake sold
Old Mar 25, 2014 | 07:56 PM
Will the LSJ rears work on an LNF fine?
Old Mar 25, 2014 | 08:08 PM
sc4door's Avatar
Only if you bought rotors, pads, calipers and their mounting brackets then it should work fine. Would probably also need LSJ brake hoses too. Parking brake cables are the same. But none of the brake hardware is interchangeable unless you swapped it all
Old Mar 25, 2014 | 08:24 PM
Thank you.
Old Mar 25, 2014 | 08:31 PM
sc4door's Avatar
No problem man
Old Mar 25, 2014 | 11:11 PM
turbosmart4's Avatar
Mmm I like the brembos
Old Mar 25, 2014 | 11:13 PM
sc4door's Avatar
Buy the brembos! Lol
Old Mar 26, 2014 | 01:02 PM
sc4door's Avatar
Old Mar 26, 2014 | 01:44 PM
alexhaf932's Avatar
How much for washer fluid tank shipped to 78577
Old Mar 26, 2014 | 01:59 PM
sc4door's Avatar
I sent you a pm
Old Mar 26, 2014 | 06:14 PM
sc4door's Avatar
Old Mar 27, 2014 | 09:56 AM
CobaltChicky88's Avatar
What year is the cluster from? If 08-10 I'd be interested.
Old Mar 27, 2014 | 10:38 AM
sc4door's Avatar
Cluster is from an 08+
Old Mar 27, 2014 | 07:57 PM
sc4door's Avatar
Old Mar 28, 2014 | 01:35 AM
m33pm33p's Avatar
Great seller and quick shipping!
