FS: 07 stage 2 cams (custom)
im waiting for the stock cams i bought...hopefully they get here monday and ill do a one for one swap this way i dont **** up the timing....but ill get pictures sooner....of them installed if you really want to see them
bumpo
Last edited by mrsilent13; Dec 14, 2008 at 02:28 AM. Reason: Automerged Doublepost
I've had packages from them that were delivered but still said in tracking that it was at the pickup station.
I would guess monday or tuesday at the latest. It is 4-5 day shipping after all.
Last edited by mrsilent13; Dec 15, 2008 at 12:10 AM. Reason: Automerged Doublepost
Did you do your own build? I know the head was already put together, but as far as pistons/rods what did you do? If you put it in the shop, how much was the labor?
I'm pretty sure you did it yourself if I remember right, but I wasn't sure.
I'd be nervous as hell to do it myself.
Here's a free bump and a question.
Last edited by mrsilent13; Dec 15, 2008 at 12:21 AM. Reason: Automerged Doublepost
yes ive done all my own work....its not that hard...i had some knowledge from high school auto shop...but then i figuered...ive worked on helicopters for the last 5 years...it cant be that much harder to break into a 4 banger....these engines are real easy to work on....all you need to do for removal of the piston and rods is remove the head and then unbolt the rod from the crankshaft and push it up and it comes right out...and then you do the reverse for installation....not hard...just tq to spec install head....make sure timing is right and your done...not too hard...but its a bit time consuming...all you need to take off from the bottom is the oil pan and you can turn the crankshaft with a ratchet to the appropriate position so you can take off the rod bolts....not hard at all....but time consuming...takes about 3 ~ 6 hours depending on your skills and tools
i would say at least 10.....thats alot of work to install all you have in there......when i did my turbo install it took me about 7 hours.......but i did half one day and half the other....its time consuming.....and for all that u are doing like the crankshaft u need to pull the block out...theres no clearance with the cradle to get it out.....so yea alot of work.....good luck
how long are you gonna hold these??? id be interested to hear about them if your gonna sell them at tax time, i had the money but bought an nx kit first lmk how long your gonna hold em for white g5
