GMR cams forsale
Rent me! per hour
GMR cams forsale
i pulled the gm racing cams out of my car, and now am putting them up forsale.
word of warning. you will need a full valve train to run these. you may or may not have to shim your lifters to accomodate the base circle.
asking 350.
asking 350.
knew it wouldn't take long. You should sell more..., people will buy if they even think you are involved in the process in some way. Good luck though. Maybe gm will wise up and produce more of these for sale in the future.
Rent me! per hour
9.5:1 c/r big cams. not a good mix. however. if one was to road race and be able to keep the rpms above 5k. it would rip serious ass
or if someone was building a highway screamer. these would do it
well. i guess i'll just give you a tip then. when you have the cams bolted down, and the gears bolted on. put the engine on tdc on number 4 piston, compression stroke. then put the cam phaser in. trust me it will save you a big headache later on
omega..
