GT 3076 Turbo kit. (COMPLETE)
Old Mar 10, 2011 | 05:48 PM
Kennyspec's Avatar
build thread https://www.cobaltss.net/forums/adva...-3-0-a-209102/
Up for sale is a complete turbo kit off of a 2006 lsj used for approx 5600kms
Garrett GT3076 ball bearing turbo 4 bolt 3" turbine outlet T3 inlet. NO SHAFT PLAY, VERY GOOD SHAPE
Garrett GT3076R (aka GT30R aka GT3037) Ball Bearing Turbo : atpturbo.com
Turbine
-Wheel: 60mm w/ 84 trim
-Housing: .63 ar
Compressor
-Wheel: 76.2mm w/ 56 trim
-Housing: .60 ar
Custom SCH10 304stainless steel exh manifold with external V band wastegate and T3 flange
3" turbo intake pipe with K&N filter
3" catless downpipe with stock o2 sensor bung and wideband bung
Tial Vband 38mm wastegate with Vband dump pipe (15psi)
Turbo Oil feed line with adapter to go into engine block and turbo oil restrictor
Turbo coolant feed, return lines
Oil Drain line (will include oil pan for a bit of extra $$ for shipping, or will just throw in a 10AN bung to be welded to your stock oil pan)
custom tig welded 16guage 2.5" diameter hot side chargepipe (goes under engine and above subframe)
Tial 50mm V band BOV
Extreme Turbo Systems intercooler 25" x 7" x 3"
ETS (95-99) 2G DSM Eclipse/Talon 7" Street Intercooler [ 2GDSM_IC_7ST ]
Custom tig welded 16guage 3" diameter cold side charge pipe with MAF bung
HAHN intake manifold with bungs for all vacuum sources. (bov, wastegate, brake booster, boost guage)
80lb/hr injectors with harness
all silicone couplers, clamps, bolts, hardware
2.2 tensioner and belt
looking to get $3200 OBO. will negotaite with buyer on shipping.
will have pics up tonight or tomorrow.
Old Mar 10, 2011 | 06:28 PM
Garret's Avatar
wow someone is in for some power. you gave up on the trannys kenny?
Old Mar 10, 2011 | 06:29 PM
Kennyspec's Avatar
didnt "give up" just moving on, picked up a 2010 camaro SS
Old Mar 10, 2011 | 06:31 PM
Garret's Avatar
ah big upgrade. Have fun with it!
Glws
Old Mar 10, 2011 | 06:35 PM
EXsoccer1921's Avatar
would you be willing to separate just the turbo? my FP 3076 just went out today...
Old Mar 10, 2011 | 06:39 PM
Kennyspec's Avatar
i would like to sell as a kit first, if it dont sell in a while then i will part out.
Old Mar 10, 2011 | 07:40 PM
flyy's Avatar
damn i wish i wouldve waited, i ought the garret kit for my 2.2 from another user for 2100 shipped. I wouldve totally dished out another 1100 bucks for this setup
Old Mar 10, 2011 | 07:43 PM
carstedt's Avatar
def interested...jus waitin on the pics
Old Mar 10, 2011 | 08:32 PM
Garret's Avatar
pics are at top under build thread
Old Mar 10, 2011 | 09:30 PM
carstedt's Avatar
i was wanting to see mayb one of the fmic on the car and a top view with everything installed..but it said in ur thread u were blowing out 2nd and 3rd gear and ur piston rings went bad...is this this kit more for a built engine rather than a stock?
Old Mar 10, 2011 | 09:50 PM
pimpnwink's Avatar
Damn this is tempting.
Old Mar 10, 2011 | 10:08 PM
pimpnwink's Avatar
would you be able to ship to America or Canada only?
Old Mar 10, 2011 | 10:14 PM
MastaShaKe_88's Avatar
I wish I would saw this when i first got my tax return s 2 late now... I'm looking for powa, but im also looking for a nice car to trade mine in GLWS man, nice kit
Old Mar 10, 2011 | 11:02 PM
pimpnwink's Avatar
Im in the same boat. I was gonna get the new sti but it would mean waiting a year or so and it has some crazy ring issues I am disappointed with. Then I was looking at picking up a C5 and having a buddy build it up to race but I would need to keep the cobalt. Im sick of it but ring went on #1 so I want to make this car more interesting.
some logic i have.
Old Mar 10, 2011 | 11:54 PM
Kennyspec's Avatar
will ship worldwide.
pics tomorow. figured out why 3rd gear was blowing out. Input and output shaft were bent causing the 2 gears not to be fully meshed and they would give out under full boost.
Piston rings cracked because the engine had 87,000kms on it and has been pushed very hard for its entire life. This kit will work fine on a stock engine at about 15-20psi but anything above that you should have at least upgraded psitons.
Old Mar 10, 2011 | 11:56 PM
pimpnwink's Avatar
what were you doing for clutch and axles.
Old Mar 10, 2011 | 11:57 PM
Projekt's Avatar
I knew this day would come
sad face
Seller is Legit. I'd feel comfortable buying human organs off of him.
Old Mar 11, 2011 | 12:00 AM
Kennyspec's Avatar
stock axels. I have a excedy hypersingle i will let go for a extra $500 if someone buys tye turbo kit.
Old Mar 11, 2011 | 12:21 AM
Kennyspec's Avatar
Pics updated in first post!!!!
Old Mar 11, 2011 | 12:24 AM
pimpnwink's Avatar
Im going to sleep on it and really consider it I cant just pass this up. I just have too many projects though.
Old Mar 11, 2011 | 09:13 AM
Kennyspec's Avatar
no need to sleep on it, just buy it!!!!
BUMP
Old Mar 11, 2011 | 10:54 AM
SCcobaltSS's Avatar
I want hotside piping! I didnt even think to run it this way when I did mine!
Old Mar 11, 2011 | 11:34 AM
Kennyspec's Avatar
if enough people in thsi thread want parts from it i will part it out.
Old Mar 11, 2011 | 12:03 PM
SCcobaltSS's Avatar
If you were to part what would you want for said hotside piping?
Do you know the thickness of the pipe?
Old Mar 11, 2011 | 01:14 PM
Kennyspec's Avatar
pipe is 16guage. trying to sell as a kit before parting out.
