Wanted Interceptor gauge,Wideband,ZZP 2.5 catted dp, Short shifter, ZZP 2.9 Pulley
Old Jan 15, 2013 | 06:03 PM
patten's Avatar
Canada Interceptor gauge,Wideband,ZZP 2.5 catted dp, Short shifter, ZZP 2.9 Pulley
Looking for some parts for my 06 LSJ.
Aeroforce Interceptor doesnt matter what color.
Wideband Gauge dont really care what kind just as long as its ready to install and will fit in stock gauge pod.
2.5 ZZP catted downpipe with bung for wideband.
Any kind of short shifter.
ZZP 2.9 Pulley.
Let me know whats out there along with prices shipped to Ontario Canada.
Old Jan 16, 2013 | 01:17 AM
Jt StageWtf's Avatar
i have a 2.8 zzp pulley i dont need
Old Jan 16, 2013 | 01:46 AM
patten's Avatar
I'm running 50's and the person thats going to do my tune was hesitating if a 2.8 would be a bit much for them. Anyone running them with a 2.8?
Old Jan 16, 2013 | 01:52 AM
rectorc08's Avatar
Straight from ZZP. Enjoy!
"They will flow enough fuel for any M62 build and many TVS builds. They support over 325WHP."
"42's have a few issues. idle is compromised a little due to bad spray pattern. They max around 2.9" pulley.
60's have a better spray pattern but are so larger, they can cause idle issues. They also require changing multiple charts in the ECU
50's are the perfect LSJ choice. They will never max with the M62, have perfect idle & great spray pattern, easy to program PCM for using only the injector size table."
Old Jan 16, 2013 | 01:54 AM
actually you can run the 2.8 on 50s .. what cooling mods do you have at the moment on your car?
Old Jan 16, 2013 | 01:58 AM
yup the 2.8 bare minimum is 45# and with the 50s you are in the clear with 2.8 pulley pm me if your interested
directly from zzp:
Required injector size for given pulley at 7k rpm
3.35 stock pulley maxes stock 34# injectors
3.1 requires 38#
3.0 requires 42#
2.9 requires 44#
2.8 requires 45#
2.7 requires 46#
2.6 requires 48#
Old Jan 16, 2013 | 02:38 AM
patten's Avatar
I'm running a dual pass and zzp s3 heat exchanger so I should be good as far as cooling.
Old Jan 16, 2013 | 04:05 AM
rectorc08's Avatar
Yeah and if you have some spare cash, pickup a phenolic spacer!
Old Jan 17, 2013 | 11:28 PM
patten's Avatar
picked up a wideband off rcarr0327.. Some how rectorc08 got me to buy his hahn catback? haha
still looking for the rest
Spanky's Monkey
Mar 7, 2016 06:06 PM
riceburner
Sep 27, 2015 11:10 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
Cptnslo
Sep 24, 2015 09:32 AM
