Wanted LSJ complete head and valve cover
lawls. Same time posting ftw.
G manz, pm me an offer on what you need.
Just an FYI though, the head is different. I believe the valve cover is different (the little circular seals at the cam ends, LSJ has the CPS where the pre-07 2.2's don't), and the actual head casting is different. The LSJ head is sand cast versus the 2.2 head which is foam cast IIRC. The LSJ probably also has different compositon exhaust valves to deal with the inherently higher temperatures you see with boost.
Last edited by ItalianJoe1; Mar 11, 2010 at 08:15 AM. Reason: Automerged Doublepost
ItalianJoe1 is correct, the valve covers wont swap without a bunch of work, im not looking for the head and valve cover for looks, as well the exhaust valves are sodium filled.
jmarks, you know you cant talk too much when your on here playin with ecotecs too
also i just sold my patriot l61 head off and need an lsj one to replace it, im already into the ecotecs
Sep 28, 2015 12:51 PM
