Fog light button
Fog light button
I'm modding my base G5 and have an SS/GT front w/fogs. My base did not have the interior trim panel with the fog button, though. How does the stock fog button attach to that panel? Can I just get a stock fog button and attach it to my panel? I know I'd need to cut into it, which is no problem. Or do I just need to get the panel with the fog and dimmer?
It's a weird hole. If you're planning on using the stock style button, you'll 100% want the factory trim piece with the hole already in place. It mounts in there kinda funky back there and isn't just a hole. On the other hand, if you're just planning on using a generic button from AutoZone or something...drilling will be just fine
Yeah, I was hoping to keep it stock looking...
How then does the stock button connect to the factory plate with the fog hole? is there a tab or something on the back that it mates to?
Try Crate Engine Depot first, they sell all the trim pieces and they're usually about 25% less than what it costs at the dealer.
Yeah the fake CF trim is harder to come by. I'm on CED's site now and they don't list the individual pieces, just the kit, but I'm sure if you give Tom a call he can sell you just that trim piece.
It has a mounting plate in the back kind of that it slips into like a glove. I don't know how to explain it, just trust me when I say a simple hole will not work with the OEM button. I've taken the thing apart about 20 times painting it different colors and I can assure you...the button will not seat in just a hole. If I feel up to it when I get home from work, I'll take it apart and post a pic of the back of that panel.
That's fail. That's really fail actually. I don't know the part number, or else I'd say try GMPD next. Without a part number, you're kind of up the creek on that one though. I just hate to see people pay dealer mark up on crap like this.
I have the wire harness for headlights and fogs, and the wiring to connect a button/switch is right behind that interior panel, so if worse comes to worse, I'll just get an aftermarket button and drill out a hole in the panel i have now... That carbon fiber piece w fog and dimmer is a PITA to come by!
if you are going to drill out a hole in the panel, make sure to cover the finish with tape to not get it scratched, center it properly, and make you are drilling the correct size hole, trying to redrill a hole is a bitch and never works nicely. if you over do the size, there's no going back and your sol
Just a quick note...did you figure this out...if you want some assistance, contact me at my email address. I will give you step by step instructions. The switch, the interior plate, etc...just did mine about 6 months ago.
Tony
Tony
i have mine wired to my parking lights so that i can run just the parking lights, or the fogs and running lights or all the lights at once. and my fogs work with my high beams too
z28addiction
Sep 28, 2015 12:03 AM
