Tinted tails
Thank you, isnt that hard once you learn to take your time and do it right
alot of wet sanding mostly
sanded the tails to get inperfections and to level the plastic 800(looks like its messed up, but its not)
cleaned the lens well
sprayed a light coat
30min
sprayed a heavy coat
30min
baked in warm oven
wet sanded the top coat with 1000 to smooth it out
cleaned well
sprayed clear
30min
sprayed clear
baked
wet sanded with 2000 to make it ultra smooth
cleaned well
sprayed clear
30min
sprayed clear medium
baked
reinstalled and waited a week, wash like normal, then apply wax. Looks like stock from the factory
oh...never knew!!!! anther ?...I can't find any sand paper above 350 grit...where did you get yours from...sounds dumb cuz in high school shop I used to be able to get it all the time!
Wally world, autozone, pepboys, just about any where. Just look in the automotive paint section. If you still cant fins them, look for the assorment pack(not emery) they usually have higher grits inside(320,800,1000,2000) If not, ill pick some up and send it to you(with money in return) or you can send them here and Ill send them back next day
