*&$@*&@% i have a huge problem...
i just took my throttlebody off and then put it all back together and now i have my engine light on and my traction light on, and it says engine power reduced, service esc, service traction control.... what the hell did i do!??
first. calm down.
next unplug ur battery for 15 min and try again.
then look over everything carefully and make sure all vacuum and electrical connections are secure. take the TB connection off and make sure non of the pins are bent.
whats the butterfly? i tried to remove the black flat spot w/ the sensor on it, but couldnt get it all the way off... so i just clipped it back on... is that what the problem is ??? if so how do i remove it completely so i can line it back up right
Yeah, you're ok. Just calm down, take the throttle body back off, make sure everything is clean and make sure it's plugged into the harness good, reinstall it carefully and you should be fine. Unplug battery for 15 mins wouldn't hurt either.
no i didnt remove the butterfly
i really didnt remove anything thats why i dont understand what went wrong
i took it back off and i took the little chrome clamps off the black thing again and noticed the orange i guess its a type of o-ring or something... but anyways, the orange thing wasnt around the edge, it was actually up in , so i worked it back to the edges and put the black thing back on... COULD that have been the problem??
well i started it up and everything still came on, but i just unhooked the battery and i guess i'll see if that works... i'm so stumped =[
nope, didnt work... lol i'm so fucked
it honestly sounds like a vacuum leak. you might have bent the TB blade. its pretty easy to do.
not much could go wrong according to the pics
as long as the gasket between the intake manifold and the throttle body is seated correctly then it should be OK.
let us know if it acts up when you start it back up.
