****tsb*****
Old Jul 12, 2006 | 05:40 PM
X3r0's Avatar
Exclamation ****tsb*****
here is a list of all the TSB
2006 CHEVROLET COBALT:
Bulletin Number: 050138016
WATER LEAKING ON FRONT PASSENGER SIDE FLOOR OF VEHICLE, WATER BLOWING OUT OF VENTS (SEAL HEATER CORE COVER). *NM
Bulletin Number: 050232005
EI05093 - CLUNK IN STEERING SYSTEM AT SLOW SPEEDS WHILE TURNING AND/OR DRIVING OVER BUMPS. *TT
Bulletin Number: 050310001A
16 INCH ACCESSORY WHEELS AVAILABLE THROUGH GMSPO. *TT
Bulletin Number: 050310011
18 INCH ACCESSORY WHEELS AVAILABLE THROUGH GMSPO. *TT
Bulletin Number: 050601027
REVISED CAMSHAFT POSITION ACTUATOR FASTENER INSTALLATION PROCEDURE. *TT
Bulletin Number: 050604073
CHECK ENGINE LIGHT MALFUNCTION INDICATOR LAMP ILLUMINATED, USUALLY WITHOUT DRIVEABILITY SYMPTOMS, DIAGNOSTIC TROUBLE CODES P0128, P0326, PO420, P0717, P2431 SET ON L61 ENGINE (FOLLOW SI, AND IF NECESSARY, REPROGRAM ENGINE CONTROL MODULE (EC
Bulletin Number: 050730015
HARD TO SHIFT OR SELECT VEHICLE GEAR, SHIFTER STICKS/BINDS/JAMS. PONTIAC PURSUIT (CANADA) 2005-2006. *TT
Bulletin Number: 050730016
TRANSMISSION CONTROL MODULE (TCM) SHORTED TO BATTERY VOLTAGE DURING DIAGNOSIS AND/OR SERVICE. *TT UPDATED. *NM
Bulletin Number: 05083
ONSTAR SYSTEM INOPERATIVE. *SC
Bulletin Number: 05084
DAYTIME RUNNING LAMPS INOPERATIVE - CUSTOMER SATISFACTION PROGRAM. *TT
Bulletin Number: 050850011
REVISED FRONT HEATED SEAT CONTROL MODULE REPLACEMENT. TT
Bulletin Number: 050864030A
INTERIOR DOOR HANDLE INOPERATIVE OR CLICKING NOISE HEARD WHEN OPENING DOOR. *TT UPDATE. *NM
Bulletin Number: 060232002
NORMAL OPERATING CHARACTERISTICS OF ELECTRIC POWER STEERING (EPS) SYSTEM DURING EXTENDED LOCK-TO-LOCK (MAXIMUM STEERING WHEEL ROTATION) USAGE. *TT
Bulletin Number: 060604012
ERRATIC FUEL GAGE READINGS (DOES NOT GO TO FULL OR MOVES OFF FULL TOO QUICKLY). *TT
Bulletin Number: 3261B
(RETAINED ACCESSORY POWER) RAP DEACTIVATES FROM DRIVERS DOOR ONLY. *TT
Bulletin Number: 3310D
SERVICE ENGINE SOON (SES) LIGHT DUE TO A P0171 - INSPECT AIR INTAKE AND OIL DIPSTICK. *TT
Bulletin Number: 3385A
REPEATED PARK LPS FUSE OPEN (ADDITIONAL INFORMATION). *TT
Bulletin Number: 3393A
BACKLIGHTING IS INOP DURING DAYLIGHT CONDITIONS (HEADLIGHT SWITCH TURNED ON MANUALLY) *SC
Bulletin Number: 3421B
ENGINE STALLS, LOSS OF ELECTRICAL SYSTEMS, AND NO DIAGNOSTIC TROUBLE CODE (DTC). INCLUDING 2005-06 PONTIAC PURSUIT. *TT *SC
Bulletin Number: 3433
SERVICE ENGINE SOON (SES) LIGHT AND SEVERE ENGINE MISFIRE ON CYLINDERS 1 AND 4 OR CYLINDERS 2 AND 3. *TT
Bulletin Number: 3492
SERVICE ENGINE SOON (SES) LIGHT AT HIGHWAY SPEEDS DUE TO A P0171 DIAGNOSTIC TROUBLE CODE (DTC). *TT
Bulletin Number: 3506A
INCORRECT MILEAGE DISPLAYED AFTER PROGRAMMING A NEW BCM. VARIOUS MODELS INCLUDING 2005 - 2006 PONTIAC PURSUIT (CANADA ONLY). *TT
Bulletin Number: 3512C
SERVICE ENGINE SOON (SES) LIGHT DUE TO A P1182 DIAGNOSTIC TROUBLE CODE - POTENTIAL CAUSES AND ISSUES. *TT
Bulletin Number: 3562C
SERVICE ENGINE SOON LIGHT DUE TO P0420 DIAGNOSTIC TROUBLE CODE ON LOW MILEAGE VEHICLES - UPDATE ECM CALIBRATION. *TT
Bulletin Number: 3627
FUEL TANK IS SLOW TO FILL AND/OR DTC P0446 - INSPECT EVAP VENT PIPE. THE SES LAMP MAY BE ILLUMINATED DUE TO A P0466 DTC. *TT
Bulletin Number: 3628
P2431 DIAGNOSTIC TROUBLE CODE AFTER ECM REPLACEMENT - INSPECT ECM PART NUMBER. *TT
Bulletin Number: 3629
PROGRAMMING ALERT: PROGRESS BAR ON TECH 2 MAY NOT DISPLAY 100%. *TT
Bulletin Number: 3634A
SES LIGHT DUE TO A P0326 DTC - INSTALL NEW ECM CALIBRATION. *TT
Bulletin Number: 3635
NO COMMUNICATION WITH ANTI-LOCK BRAKING SYSTEM AFTER EBCM REPLACEMENT. TO INCLUDE 2006 CHEVROLET HHR. *TT
Bulletin Number: 3641A
REAR SUSPENSION SQUAWK/SQUEAK OVER BUMPS. *TT
Bulletin Number: 3642
SES LIGHT WITH A P0230 DTC AND NO PERFORMANCE CONCERNS - REPLACE ECM. *TT
Bulletin Number: 3644
MOMENTARY SAG ON LIGHT TO MODERATE ACCEL WHEN COLD - VALVE DEPOSITS. *TT
Bulletin Number: 3646A
SES LIGHT DUE TO DTCS P1516 AND P1682 - ECM CALIBRATION PENDING. *TT
Bulletin Number: 3648
HESITATION ON ACCELERATION AFTER INTERNAL ENGINE REPAIRS - CHECK INJECTOR HARNESS ORIENTATION. *TT
Bulletin Number: 3673
CRUISE CONTROL INOPERATIVE AND/OR MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0833 STORED. THE CONDITION MAY NOT BE ABLE TO BE DUPLICATED BY THE DEALER YET THE CONSUMER MAY HAVE A REPEAT CONCERN. *AK
Bulletin Number: 3687
CLUNK NOISE FROM FRONT OF VEHICLE DURING TURNING MANEUVER. *SC
Bulletin Number: 3688
SUNROOF SWITCH BEZEL FALLS FROM THE HEADLINER. *TT
Bulletin Number: 3757
SUNROOF INOPERATIVE BINDING OR STUCK. *TT
Bulletin Number: 3759
SES LIGHT DUE TO P060E DTC - INSPECT CIRCUITS. *TT
Bulletin Number: 3786
NO START AFTER ENGINE HARNESS REPLACEMENT (NON-ABS). *TT
Bulletin Number: 3799A
SIR LIGHT ON/SERVICE AIR BAG WARNING MESSAGE WITH DIAGNOSTIC TROUBLE CODE B0081. *AK
Old Jul 15, 2006 | 07:39 PM
jokieman's Avatar
That doesn't look like all of them, I believe there's over 60 tsb's out for the cobalt right now, but only 30-40 of them are tracked by the feds as being possible "safety" issues.
Old Jul 15, 2006 | 09:43 PM
One Bad SS's Avatar
Does Gm send a TSB about the damn flaking 18 inches wheels ?????
Old Jul 15, 2006 | 09:51 PM
Clmbngfrk18's Avatar
any one know the one for the idle problems mines doing it all the time now
Old Jul 15, 2006 | 09:58 PM
SS33's Avatar
^I seriously need to take mine in for that one too. Hopefully this week.
Anyone know the #
Old Jul 16, 2006 | 02:28 PM
\DARKMETL/'s Avatar
So how does this work? I just got mine july 1st. Do you take it in when you have these symptoms or what? Are they required to fix all of these things at once even if you arent having sypmtoms yet?
Old Jul 16, 2006 | 02:35 PM
xspyder85x's Avatar
anyone else having the sqeaks? how is it fixed?
Old Jul 16, 2006 | 04:08 PM
red-SS's Avatar
I have the door handle click
Old Jul 16, 2006 | 04:23 PM
REIGN SS's Avatar
Original Hayden Fanatic
i have a sqeak in the front passenger side. Not a rattle from the inside, but a sqeak, sounds like its outside.
Old Jul 16, 2006 | 07:52 PM
Yikes12345's Avatar
I have a squeak on the right front too. I hear it more when I go over bumps though. Who knows.
Old Jul 16, 2006 | 11:17 PM
X3r0's Avatar
i just brought mine in and told them what it was doing and i had the TSB number
Old Jul 18, 2006 | 06:54 PM
keeper51's Avatar
I'm taking mine in tomorrow for the steering column clunk i'm getting, gonna hit 60 000 km's tomorrow taking it into the dealership. They said that it won't be covered after
60 000 and i'll be at like 60 040
Old Jul 20, 2006 | 09:56 PM
jokieman's Avatar
They're required to fix TSB's only when the symptoms show themselves. It's not the same as a recall where they have to fix all the cars of certain build dates whether symptoms appear or not.
Old Jul 20, 2006 | 10:00 PM
jokieman's Avatar
http://www.alldata.com/TSB/061057_en.html
Gives a list of the titles of all the tsb's available. I did not see one for the flaking, but they have a few dealing with wheels/tires.
Old Nov 21, 2006 | 10:21 AM
BlkSdn's Avatar
I can't seem to find any information on this one. I have a subscription to infotraxx, but it is not listed. Can someone provide more info?
Old Nov 21, 2006 | 01:01 PM
rnjmur's Avatar
Here is a much better site for looking up tsb for vehicles.
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/
Old Nov 21, 2006 | 01:52 PM
BlkSdn's Avatar
Been there. Problem is they only show the summary, which I can get anywhere. What I want is the actual bulletin itself. I can request mor einformation fromt he NHTSA, but it would require me to pay some unspecified amount for someone to copy, etc.
Old Nov 21, 2006 | 03:55 PM
rnjmur's Avatar
oh well yeah... stupid people and their damn charging money for everything... what do we live in a capitalistic government or something.... oh wait... LOL
Old Nov 21, 2006 | 04:47 PM
fr33k's Avatar
Is this the one your refering to?
Document ID# 1869035
2006 Chevrolet Cobalt
Subject: Information on Inadvertent Turning of Key Cylinder, Loss of Electrical System and No DTCs #05-02-35-007A - (10/25/2006)
Models: 2005-2007 Chevrolet Cobalt
2006-2007 Chevrolet HHR
2005-2006 Pontiac Pursuit (Canada Only)
2007 Pontiac G5
2006-2007 Pontiac Solstice
2003-2007 Saturn ION
2007 Saturn Sky
This bulletin is being revised to add a model year. Please discard Corporate Bulletin Number 05-02-35-007 (Section 02 - Steering).
There is potential for the driver to inadvertently turn off the ignition due to low ignition key cylinder torque/effort.
The concern is more likely to occur if the driver is short and has a large and/or heavy key chain. In these cases, this condition was documented and the driver’s knee would contact the key chain while the vehicle was turning and the steering column was adjusted all the way down. This is more likely to happen to a person who is short, as they will have the seat positioned closer to the steering column.
In cases that fit this profile, question the customer thoroughly to determine if this may the cause. The customer should be advised of this potential and should take steps to prevent it - such as removing unessential items from their key chain.
Engineering has come up with an insert for the key ring so that it goes from a "slot" design to a hole design. As a result, the key ring cannot move up and down in the slot any longer - it can only rotate on the hole. In addition, the previous key ring has been replaced with a smaller, 13 mm (0.5 in) design. This will result in the keys not hanging as low as in the past.
Parts Information
Part Number
Description
15842334
Cover, Dr Lk & Ign Lk Key
Old Oct 27, 2010 | 06:51 PM
devon9832's Avatar
I hate to wake a dead horse, but since I have a '06 and I'm hearing the clunking noise is it too late to take mine in for some issues that I'm having and they can fix it using the bulletin number?
Old Oct 27, 2010 | 07:38 PM
Malaclypse's Avatar
If you're out of warranty, no. They won't fix it for free.
A bulletin is not like a recall.
Old Oct 27, 2010 | 08:39 PM
devon9832's Avatar
Damn it all... Thanks man.
