06 SS/SC right front tire rubs
Old Aug 23, 2006 | 03:54 PM
Superdave420's Avatar
ok is this a normal thing for the 18's that come on a stock 06 SS/SC to rub when making any right turns? mine do it all the time and 1 thing it is embarrassing. other thing tires are not cheap lol. I looked under the right wheel well and see a body panel or seomthing righ smak in the middle of the well hainging lower then I'd like.
Old Aug 23, 2006 | 03:56 PM
distillion's Avatar
i get a lil rub if my wheel is turned all the way...............ON SPORTLINES, the only reason is cuz my intake buldges out the fender line just a tad.
so no its not normal.
Old Aug 23, 2006 | 04:03 PM
M-Dub's Avatar
I have no rubbing issues... stock springs and the 215's... I can do lock to lock turns with no problems! So NO it's not normal!
Old Aug 23, 2006 | 04:06 PM
wdsoccer's Avatar
Take it to the dealer to check it out.
Old Sep 8, 2006 | 01:30 PM
taking it to the dealer tomorrow, we'll see what they say
Old Sep 8, 2006 | 01:34 PM
mken's Avatar
225's on mine and they don't rub, either.
Old Sep 8, 2006 | 01:44 PM
SSinPhilly's Avatar
get it checked out
Old Sep 12, 2006 | 09:48 PM
Coblasts's Avatar
Canada Mine rubbed to
Right side ground effect moulding not at aright angle ,part problem needs to be replaced or refastened better.
You have to break pretty aggressive and steer hard right for it to happen.
Need to take mine in to but waiting for a few things to make it worth being with out it.
Old Sep 13, 2006 | 10:58 AM
mine is now fixed via warranty, the right fender epoxy had let loose and the fender dropped a tad and this caused a "twist" in the ground effect and made it run under light braking and light right handed turns. the part of the fender that is closest to the windshield was SUPER loose and the other fender was nice and tight, all fixed now. really cool now not worrying about the rub.
Coblasts check the fender top, the edge closest to the windshield and see if your is loose as well
Old Sep 13, 2006 | 11:02 AM
oldsskool's Avatar
I had a similar issue, mine was the end cap on the side skirt, like in your picture where your white sitcker is in the DSF wheel, that cap, the end of it was sticking out, took it to the dealer and they popped another black screw into it and VOILA .. haha
Old Sep 13, 2006 | 11:58 AM
PlaysWitCars's Avatar
Former Cobalt Owner
no rubbing here......on sportlines also.....even my 19s dont rub. but we will see which the H&Rs go on.
Old Sep 13, 2006 | 12:27 PM
suburbanrobot's Avatar
mmmmm 225's
my stock 215's don't rub
RaginChopsuey
Oct 27, 2015 01:27 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
SSLOW06
Oct 1, 2015 07:21 PM
DANRICKARD
Oct 1, 2015 12:08 AM
grampss
Sep 27, 2015 08:51 PM
