07 Cobalt Coolant
Old 04-15-2012, 02:48 AM
CobaltItaliano's Avatar
07 Cobalt Coolant
I am running a bit low on coolant right now, and I have some Peak extended life 50/50 antifreeze. I know the current coolant is dexcool, but the Peak bottle says it can be mixed with any coolant in any make/model.
So does anybody know if its safe to add to the dexcool or should i just go buy some dexcool and add it in?
Thanks
Old 04-15-2012, 10:22 AM
Coblasts's Avatar
Stick with the dexcol,
I think using one of those so call compatible brands was the demise of the intake gasket on my Safari van.
It's takes along time but the gaskets are dexcol compatible and the other coolant types may rot the gaskets out or worse yet turn the coolant into syrup.
This is my opinion
Old 04-15-2012, 10:24 AM
mexi_loco's Avatar
if you want to use the yellow ****, drain out the rest of the dex-cool first via the plug in the radiator. Don't mix different colors. But then again, I wouldn't be putting that **** in my car to begin with. Dex-cool is what they put, so dex-cool is what I put.
Old 04-15-2012, 12:01 PM
nhanson's Avatar
Just use dex. Either from the dealer or the Prestone specific dex bottle
Old 04-15-2012, 12:08 PM
nizzle's Avatar
DO NOT mix. Use dexcool only or COMPLETELY flush system before changing coolants
Old 04-15-2012, 01:53 PM
Thanks guys. This work?
Prestone/1 gal. 50/50 Dex-Cool antifreeze and coolant (AF850) | Antifreeze | AutoZone.com
Old 04-15-2012, 02:01 PM
mexi_loco's Avatar
that'll work, but you're basically paying for half a jug of water as well. I'd rather buy the concentrate and add water later. But if you don't have a constant source of purified distilled water, then just get that and call it a day.
Old 04-15-2012, 02:03 PM
Prestone/5/100 extended life antifreeze and coolant (AF888) | Antifreeze | AutoZone.com
Thats the other one they have. It says concentrate, but not sure what the 5-100 means?
Old 04-15-2012, 02:28 PM
johnccc's Avatar
I would actually get the Prestone Dex-Cool (GM logo on package) non premixed and make a 70/30 mix for even better protection, but 50/50 will work fine however.
Remember to flush your system with radiator flush if you plan to drain it anyway, a few more dollars makes a cleaner cooling system.
Old 04-15-2012, 02:30 PM
Never done a radiator flush before. Ive got a 07 with only 27k miles on it. And the coolant is still good in color and not at all sludgy. Is it safe to just add a 50/50 mix of the above stuff or no?
Old 04-15-2012, 02:38 PM
mexi_loco's Avatar
you should perform a coolant flush every 1-2 years, or every 30,000 miles (which ever comes first), irregardless of how it "looks" (that's a subjective measurement). When you jack the car up, find the radiator and look at its bottom. You should notice a plastic screw at its lowest point. That is the drain plug where you will drain the coolant system of all its coolant.
To do this, you will have to turn your car on (after unscrewing the plug), and run the heater at its highest setting. The minute you see the stream reducing, immediately turn the car off (otherwise, you'll probably hear the car misfiring or even knock). Reinsert the drain plug and fill the overflow tank with the recommended amount of coolant/water mixture (check out your owner's manual).
Old 04-15-2012, 02:46 PM
Guess I should just do it the right way and do the flush instead of just adding to the fill line then?
Old 04-15-2012, 02:52 PM
mexi_loco's Avatar
it's up to you. I mean if it's never been flushed before then yeah, it's way overdue for one.
Old 04-15-2012, 02:55 PM
Yeah never been flushed before since the manual says every 5 years 150k miles. But might as well just flush it now since Im in need of coolant. No time this week..hopefully next weekend. Thanks man.
Old 04-15-2012, 02:56 PM
heathkidder's Avatar
Do u guys use same coolant for h/e also or two diff kinds incase you have a leak ull no what it is
Old 04-15-2012, 02:57 PM
Not sure. Ive got a 2.2
Old 04-15-2012, 03:01 PM
mexi_loco's Avatar
5 years, 150k??? awe lawdy any half-way decent tech will tell you 1 year, or 30k miles.
I ran straight dex-cool for awhile, but honestly, 50/50 water-dex cool is what's recommended. Wish I had datalogs to compare how it ran between the two, but never got around to it.
Old 04-15-2012, 03:02 PM
Ok then yes use the gm orange kind i thought u might be sc bc i used the yellow stuff for my h/e bc i didnt want to use same color
Old 04-15-2012, 03:04 PM
I use gm orange kind for main coolant and yellow kind for h/e which iv never used before but i didnt want both systems orange
mexi_loco's Avatar
Use dex-cool for the s/c as well. I just wouldn't use anything but what came from the factory.
Old 04-15-2012, 03:06 PM
But does it come in another color than orange all i found was yellow 50/50 but i thought there was a pink
Old 04-15-2012, 03:10 PM
mexi_loco's Avatar
no sir. Someone either:
(a) diluted their dex-cool coolant too much and appeared pink, or;
(b) you saw automatic transmission fluid somewhere (which is red/pinkish).
Only use dex-cool in your cooling system and s/c system with clean, distilled and purified water.
Old 04-15-2012, 03:12 PM
Hmm i judt didnt want them both same color Incase of a leak id no where to start
Old 04-15-2012, 03:14 PM
Well ill ask u another dumb ? Then uno how u can see the temp gauge on ur cluster well is there anyway to find out temp for the h/e system
mexi_loco's Avatar
they are independent systems of each other. It will not matter what color the coolant is; it's already going to be an easy way of determining if the block is leaking or the s/c system.
Quick Reply: 07 Cobalt Coolant
