09 LS cruise control Mod question
Old Jul 14, 2011 | 10:00 PM
smokensteve's Avatar
Unhappy 09 LS cruise control Mod question
Hello all....this is my first post on this forum...I have done the cruise control mod to my 09 Cobalt LS..everything went good. I bought a donor steering column from a wrecker and the old BCM connector for the wires.....i installed the cruise control onto my original steering wheel...used the harness inside the steering wheel from donor column and ran 2 wires from the back side of SIR on the column, down to my BCM...I have power to the new Cruise module and the info buttons work like they should...when I took my vehicle to a mechanic he told me that the BCM was locked and all he could change was my wheel size...I called local GM dealer and I was told I would have to buy a new BCM and have it programed..the mechanic charged me $120 to tell me that BCM was locked...took them about an hour ..mechanic said he tried to flash BCM from internet...no luck...so I am into this for about $250 right now...not sure if I have wasted my time and money...please help.....!!!!!!!guess what I really want to now is if GM is blowing smoke or are they right...can I somehow unlock the BCM so a tech 11 is able to turn the cruise option on?
Old Jul 14, 2011 | 11:18 PM
Maven's Avatar
I havent had this issue yet, the BCM only locks to the VIN, I havent had any where the only option changeable was tire size.
Old Jul 14, 2011 | 11:42 PM
hm...ok...well can ya help me out cause thats what I am dealing with....is there something the tech has to do with the tech II
Old Jul 16, 2011 | 07:44 AM
06SS ALL DAY's Avatar
why would you go through all that for cruise control?
Old Jul 16, 2011 | 09:04 AM
Maven's Avatar
Yes you have to go into the BCm with the tech2 and select the cruise control option
Why would you go through all that? because for instance I know in 2008 models cruise control was essentially a $1700 option. you need to upgrade from an LS to an LT and then it was like another $300 option. So I installed cruise in my LS, and since then quite a few other people have as well.
Old Jul 16, 2011 | 09:35 AM
cranemaster's Avatar
Fuel economy
Old Jul 16, 2011 | 12:08 PM
because i drive on the highway for work.
Old Jul 16, 2011 | 12:11 PM
[QUOTE=Maven;5915681]Yes you have to go into the BCm with the tech2 and select the cruise control option
Why would you go through all that? because for instance I know in 2008 models cruise control was essentially a $1700 option. you need to upgrade from an LS to an LT and then it was like another $300 option. So I installed cruise in my LS, and since then quite a few other people have as well.[/QUOT
like I said my bcm is locked according to mechanic.....he can't get in with the tech 2....does anyone one have any info on how to unlock a bcm...or has anyone run into this problem
not getting anywhere here...so far just drivle...lol
Old Jul 16, 2011 | 09:51 PM
Maven's Avatar
[QUOTE=smokensteve;5915862]
Well either something is wrong with your BCM or your mechanic. The BCM doesnt "lock" itself.
Old Jul 25, 2011 | 05:37 PM
Success...lol....finally found someone compitent on the GM Tech 2 scanning tool...he had me up and running in about 15 mins....I know have cruise control...was wondering about ABS...does anyone know if this is something fairly easy to upgrade to?Mechanic showed me options in the tech 2...ABS was one of them..it is turned off in my BCM...is this an easy upgrade to ABS brakes?
brandon04
Oct 21, 2015 07:04 AM
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
