'10 ss o2 sensor won't reach zzp 3" downpipe
Old Jun 30, 2021 | 05:26 PM
ToxicBiz's Avatar
I just put in my new 3" zzp downpipe and the O2 sensor won't reach the hole. I did get an extension wire harness in the box but I can't find the other end of the o2 sensor to use the extension. Any help on location of the wire plug would be helpful ! Do I even need to use the sensor or just plug the hole it with a bolt ? Thank you.
Old Jun 30, 2021 | 08:28 PM
ToxicBiz's Avatar
Solved
If you're under the car you'll have to move all the way to the front and it's on top of a joint. It's kind of hard to see and you'll have to move the connectors to see the clips.
06_SIC_SS
Jul 25, 2009 06:17 PM
mjesenovec
Mar 6, 2008 10:41 AM
Try2k
Jul 1, 2007 09:57 AM
Doc
Jul 29, 2006 02:56 PM
