12V plug not working?
Old Jul 21, 2008 | 12:37 AM
Chad92's Avatar
Yet another thing the GM techs are working on tomorrow. The 12 volt plug just under the air controls is only feeding 0.01 volts to anything attached. The one down by the e-brake is working fine.. 12.54 -12.57 volts steady. Checked fuses and they are all fine. What could be wrong?
Old Jul 22, 2008 | 01:57 PM
Hotwired2689's Avatar
i have the same problem, but the opposite, the plug down near the ebrake handle is out, i checked fuses in both locations and had to replace one and still doesn't work :/ im bringin my car in to the dealer today for other work o.0
i'll let u kno what they say
Old Jul 22, 2008 | 01:59 PM
bgbearcatfan's Avatar
did you check the fuses under the hood as well? Because the obd2 port and front cigarette lighter are on the same fuse, and thats in the fuse box under the hood
Old Jul 22, 2008 | 03:25 PM
thanks i'll give it another look, hopefully i can find it before i bring my car intoday for "service" lolol man they'll freak out when they cant check anything cuz the OBDII port is out
Last edited by Hotwired2689; Jul 22, 2008 at 03:26 PM. Reason: Automerged Doublepost
Old Jul 22, 2008 | 09:02 PM
Chad92's Avatar
I took mine in to get fixed with some other issues (wind noise, bump in steering, hard shifts on an auto), and they fixed it. They haven't finished my work order so I don't know what they did to fix it. I'll know Monday.
Old Aug 5, 2008 | 11:11 AM
menace066's Avatar
im having the same problem with the 12v plug down by the e-brake, any update on how to fix it?
Old Aug 5, 2008 | 11:22 AM
Chad92's Avatar
There is a fuse somewhere that blows. I'll know tonight when my car is done and I get a copy of the work order.
Old Aug 5, 2008 | 11:35 PM
Chad92's Avatar
Well, got my car back, and they told me nothing in the work order. Here's what it said:
Originally Posted by Chad92's Work Order
COMPLAINT: REPAIR CUSTOMER CONCERN OF 12V OUTLET UNDER STERIO INOP(OJ)
CAUSE: I VERIFIED CUSTOMER CONCERN. INSPECTED POWER OUTLET FOR CIRCUIT CONTINUITY. FOUND POWER SUPPLY CIRCUIT OPEN. INSPECT CIRCUIT FUSE- FUSE IS OPEN (6F). FUSE REPLACEMENT IS REQUIERED.
CORRECTION: REPLACED BURNED FUSE AND OPERATED SYSTEM. POWER OUTLET IS FUNCTIONAL. RELEASED VEHICLE. CUSTOMER CAME BACK AFTER COUPLE HOURS WITH SAME CONCERN. INSPECTED FUSE- FUSE IS OPEN REPLACED FUSE AND USED TECH 1 TO VERFIY OPERATION- CIRCUIT IS FUNCTIONAL. AFTERMARKET DEVICE USED BY CUSTOMER IS CAUSING PROBLEM. REPAIR IS COMPLETE AND CONFIRMED.
PARTS------QTY---FP-NUMBER---------------DESCRIPTION---------LIST PRICE-UNIT PRICE-
JOB # 3 1 88909754 FUSE KIT 089650 SP WARRANTY
15-MINI
Hopefully that helps a little.
Old Aug 5, 2008 | 11:39 PM
EmperorJJ1's Avatar
what aftermarket electronics do you have?
Old Aug 6, 2008 | 12:55 AM
Chad92's Avatar
Samsung A720 12V Car Charger and an iPod dock that plugs into the other 12V plug. I can take pics if needed. The draw of the 12V car charger is 770 mA... hardly anything through the 15A fuse. Funny thing is, only the plug that is used for the car charger blows, the one by the ebrake still works.
Old Aug 6, 2008 | 12:56 AM
do you have anything pluggedinto the obdII port?
Old Aug 6, 2008 | 12:57 AM
Chad92's Avatar
Nope, nothing.
Old Aug 6, 2008 | 12:59 AM
EmperorJJ1's Avatar
sounds like the dealership gave u a load of BS
Old Aug 6, 2008 | 01:26 AM
Chad92's Avatar
Probably. They wouldn't tell me which fuse was blown. I checked to see if there were any blown before I took it in, and the one under the hood for accessory power and the trunk wasn't blown, and there wasn't anything for those plugs in the fuse box in the center console. Dumb stealership. Thank God for bumper to bumper warranty!
Old Aug 6, 2008 | 01:28 AM
EmperorJJ1's Avatar
plus they cant spell stereo
is it working now?
Old Aug 6, 2008 | 01:57 AM
Chad92's Avatar
Yeah, working fine now. It better stay that way too.
Old Aug 6, 2008 | 11:56 AM
ticketdoctor's Avatar
Mine under the A/C controls doesn't work either. I think I burned it out trying a cig lighter in it lol...haven't checked fuses yet though.
Old Aug 6, 2008 | 12:01 PM
OzzyruleZ's Avatar
I've popped the one under my AC controls a few times now. With a phone charger and a G-Tech. I think that circuit needs a little bigger fuse. I just use the one by my ebrake most of the time. It hasn't popped yet.
Old Aug 6, 2008 | 11:23 PM
Chad92's Avatar
I'm thinking so too. I think what's in there is a 5 amp right now. Next time it goes I'm going to replace it myself and put in a 10 amp or a 7.5. Enough is enough!
Old Aug 6, 2008 | 11:52 PM
Coblasts's Avatar
LTR fuse 15 amp under the hood.
Could be something wrong with the part you put in the lighter,There is no way that would blow a 15 amp fuse with that equipment unless you wired some aftermarket electronics to that circut.
Old Aug 6, 2008 | 11:55 PM
CobaltVenomSS's Avatar
mine under the AC dont work all that goes in it used to be a radar...now i gotta plug my radar into the e brake one and i have a wire from the windshield to the plug :/
Old Aug 6, 2008 | 11:59 PM
Coblasts's Avatar
Check the ltr fuse under the hood
Its 15 amps
Old Aug 7, 2008 | 12:55 AM
Chad92's Avatar
Damnit. I guess I'm buying a 20. :P
Mine's working fine now, working longer than it did last time!
Old Aug 8, 2008 | 10:26 AM
Coblasts's Avatar
The fuse is to protect the wire !!
You could create a big problem for your self once the wire heats up instead of the fuse blowing and the all melt together.
The lighter is fed straight from the battery you have a short somewhere if not in the equipment your plugging in.
Old Aug 9, 2008 | 02:01 AM
EmperorJJ1's Avatar
^^^ x2 bumping up the fuse doesnt fix anything
