16 at most
16 at most
All right first off if you look at my sig you can see i have a 2.6 pulley, well i tuned it my self, and yaadddda yaddda, well i ported the charge, but not alot at all, i mean i just did another port and i took off more with that one, and the guys s.c has a 2.8 and he is making mor boost then i am. I am only making 16 and the needle shakes like it is on crack, like the bypass is opening up, i unplugged the vacum line and i got around 17-18. Wut i am asking is boost should keep the bypass valve arm down to keep the throttle (bypasse) closed accept for at idle. so why would it be opening at boost????
