2.2L Question
Old Sep 3, 2006 | 09:29 PM
chipsgt's Avatar
2.2L Question
hey guys!
Got a question and I wanted to see if any of you 2.2 guys have had the same issue or not.
My Mother in law has an 05 2.2 Sedan.
She has been having the problem of sometimes when she switches between her low and hi beams, that there will be a moment of not having any lights at all.
I was wondering if anyone has had this problem and knows if there is a fix for it, or a service bulletin out or not.
Thank in advance!
Old Sep 3, 2006 | 09:33 PM
mkulrey13's Avatar
hmm when i switch there is maybe a half od a split sec of no lights but its so fast you dont notice it.
Old Sep 3, 2006 | 09:42 PM
chipsgt's Avatar
Yeah, from what she described, she actually goes for a second or two without any lights at all, leaving her driving in the dark.
Old Sep 3, 2006 | 09:43 PM
SK63's Avatar
I've noticed a slight delay, but nothing as long as you described.
Old Sep 3, 2006 | 10:06 PM
YSUsteven's Avatar
Sounds like the relay is sticking..
had a similar thing happen on a 95 Grand Am. Cycled high to low several times in a row and the problem never came back, worked fine for an additional 10,000, until I sold it.
You could just take it to the dealer if it does this all the time.
Old Sep 3, 2006 | 10:07 PM
SSinPhilly's Avatar
check your dl relay and fuses-
Old Sep 3, 2006 | 10:15 PM
HackAbuse's Avatar
I have looked for the headlight relays before but was never able to find them
Old Sep 5, 2006 | 07:34 PM
marshall's Avatar
my headlites go completely out when on hi with left blinker on. with rite blinker on they go to hi and low beam at the same time. i had my rite headlite replaced because of water in the lens and now this happens.
Old Sep 5, 2006 | 08:10 PM
djpatrick35's Avatar
Luckily I've never had that happen, so I'd utilize that old warranty, baby!
Old Sep 5, 2006 | 08:13 PM
YellowLT's Avatar
Mine does this but it just started happening recently
Old Sep 6, 2006 | 08:34 AM
chipsgt's Avatar
Well, I told her it might be the relay, and I think she is going to take it to the dealer.
I will let you guys know what comes of it!
Thanks for the reponses!
Old Sep 6, 2006 | 11:56 AM
Adirondack_Cobalt's Avatar
the switch is shot.
there are no relays
it's all controlled by the BCM...
just had this repaired in my 05 base Cobalt coupe.
As it gets worse, the headlights will shut off when flipping the signal lights on... very exciting when getting back into a lane after passing someone.
Scott
Old Sep 6, 2006 | 02:13 PM
HackAbuse's Avatar
Originally Posted by Adirondack_Cobalt
the switch is shot.
there are no relays
Scott
That sucks
So the BCM makes clicking noises just like relays when i turn the lights on and off? Becuase I can hear clicks similar to relays under the hood when fudginf around with my lights
Old Sep 7, 2006 | 01:36 AM
Originally Posted by HackAbuse
That sucks
i was out in the shop when they changed my headlight switch and I asked if there was a relay or something... the guy doing the job told me that all these new GMs were running everything right through the BCM so if the 'relay' in the bcm conks out, your fuckaroo... you've gotta replace that computer to the tune of $300-400... ouch.
Scott
Old Sep 7, 2006 | 01:45 AM
joeworkstoohard's Avatar
That sucks
the clicks are FAKE. get this. i was riding the other day, and i was waiting to turn, so the turn signal was on. meanwhile the car was bitching that i didn't have my seatbelt on.. so the clicking STOPPED while it chimed and continuted after it was done.
Old Sep 7, 2006 | 02:14 AM
HackAbuse's Avatar
I was getting at the fact that, when the engine is off, and the hood is up, If i stand next to my car and flash the high beams on and off, there's a relay clicking noise coming from underneath the fusebox
Old Sep 7, 2006 | 02:16 AM
there has got to be a relay SOMEPLACE. i highly doubt it's all electronic... that would be a lot more complex than i really needs to be. i'm thinking that the sending unit it probably electronic and the actual lamp is attached to a 3 way relay (high, low, off) for blink, DRL and well, off.
Old Sep 7, 2006 | 09:54 AM
06cobaltls's Avatar
i get a small instant of darkness with mine, but maybe only half a second
brandon04
Oct 21, 2015 07:04 AM
ThoR294
Oct 4, 2015 08:44 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
