2005 cobalt ss supercharged problems running!
Old Jun 29, 2014 | 04:24 PM
davidtut4's Avatar
Hello I have a 2005 cobalt ss supercharged stage 3 water meth, the CEL never came on, but the car died out. It has spark, great compression and I changed every sensor on it but when I go to start it, it fires up then dies right out, I am wondering if it's something like security or what the problem is it seems electrical, and it's weird that it didn't ever throw a code anyone have this issue? Or can help?
Old Jun 29, 2014 | 04:33 PM
TStone's Avatar
Unplug the mass air flow sensor and see if it'll run
Old Jun 29, 2014 | 04:41 PM
davidtut4's Avatar
It has a brand new MAF sensor, but I guess brand new doesn't always mean not defective. I will definitely try it as soon as I get home, thank you! I'll let you know if it runs or not
Old Jun 29, 2014 | 05:33 PM
TStone's Avatar
Security light on?
Old Jun 29, 2014 | 06:51 PM
davidtut4's Avatar
Now that you mention it I think I did see the security light on
Old Jun 29, 2014 | 06:52 PM
TStone's Avatar
Well that could explain it
Old Jun 29, 2014 | 07:01 PM
davidtut4's Avatar
How would I get security lock off?
Old Jun 29, 2014 | 07:05 PM
TStone's Avatar
try unhooking the battery for 10 minutes... hooking it back up and trying it.
Old Jun 29, 2014 | 07:07 PM
ItalianJoe1's Avatar
Start and die is almost always the security system, it will allow it to run for about two seconds then kill everything if the wrong key is used.
Do you possibly have another key that works?
Old Jun 29, 2014 | 07:20 PM
davidtut4's Avatar
The battery was dead for awhile so it hasn't has power till today when I charged it, and no I only have the 1 key and key fob
Old Jun 29, 2014 | 10:23 PM
davidtut4's Avatar
Unfortunately I just came in from looking at it, the security light isn't on, so it has to be something more then that, like the car I turn it over it starts then dies within 12 sec no check engine light ever came on I'm lost. The mods are flashed and tuned ecu, water meth, typhoon k&n intake and other mods internally I have no clue what could cause this to happen, car ran great then shut off 1 day, changed basically every sensor, hooked up to 2 different readers and absolutely no codes popped up
Old Jun 30, 2014 | 08:23 PM
Fuel pump dying?
GaryGibblez
Jan 14, 2020 10:35 AM
Green
Sep 13, 2015 01:30 AM
Josh@ottp
Sep 8, 2015 10:18 AM
medic710
Sep 6, 2015 08:53 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
