2007 LSJ: WTH did the PO do to the engine(Pic)
Old Jan 2, 2017 | 04:05 PM
Mysterion's Avatar
I've had the car for a month now and been fixing random things and today I noticed the evap solenoid disconnected, I also notice the coolant overflow going into the throttle body
Should I disconnect the overflow hose and connect the throttle body hose to the evap solenoid? Is that 1/4" both sides correct? Thanks in advance
Old Jan 2, 2017 | 04:40 PM
Sharkey's Avatar
yes, unhook that right away. im not sure on the size, from factory is uses a formed plastic line with quick connect couplers. a piece of rubber vacuum hose should work on though, just measure the nipples
Old Jan 10, 2017 | 11:21 PM
ItalianJoe1's Avatar
If you haven't already fixed this, I have a bunch of those factory plastic lines that you are missing, if you need one let me know.
Old Jan 11, 2017 | 08:04 PM
Mysterion's Avatar
Thanks but I've since fixed it with a coolant hose from advance auto.
Old Feb 16, 2017 | 11:16 PM
chris88z24's Avatar
Lmao @ the overflow hose plugged into the throttle body.
