2009 Chevy Cobalt SS Cam Sensor Location?
Old Feb 11, 2013 | 07:37 PM
iboost's Avatar
Question 2009 Chevy Cobalt SS Cam Sensor Location?
I have been searching all over the place for this answer. Maybe I am missing something. When I search I get multiple answers. The two sensors on top of the motor in the valve cover some people call "cam position sensors" and some call them the "cam position actuators." So...which is it. If they aren't the "sensors" where are they located on the motor. Thanks for your help.
Old Feb 11, 2013 | 07:38 PM
user 72239's Avatar
From my understanding, the two on the top of the motor by the timing chain are the cam shaft actuators and the actual cam shaft sensor is under the HPFP.
Old Feb 11, 2013 | 07:42 PM
iboost's Avatar
I appreciate the quick response. I wanna see what everyone collective opinion is on it.
Old Feb 11, 2013 | 07:57 PM
09CobaltSS1's Avatar
^^This
In the pic I attached "Red" is the position sensor, "Blue" is the intake cam actuator, "Green" is the exhaust cam actuator. The 2 actuators are next to #1 coil pack on the valve cover.
Old Feb 11, 2013 | 08:05 PM
iboost's Avatar
Thats PERFECT! Lol thank you. Now is there anything complicated about replacing that?
Old Feb 11, 2013 | 08:12 PM
user 72239's Avatar
its 1 10 mm bolt. I tried getting it off without taking the HPFP off but it was too hard. just easier to take the HPFP off
Old Feb 11, 2013 | 08:13 PM
iboost's Avatar
Awesome thanks
Old Feb 11, 2013 | 08:14 PM
Which one? The actuators or the position sensor?
The actuators are literally the easiest thing you will probably ever fix.. lol. Each actuator is retained by 1 10mm bolt and then they pull straight out. Lube o-ring on new actuator and install the same way. Just make sure you don't mix up the intake for the exhaust actuator and vice versa. The position sensor is a little more involved only because it's not as in your face as the actuators but is still not very difficult. It's also retained with 1 10mm bolt.
Old Feb 11, 2013 | 08:35 PM
iboost's Avatar
thanks man. Much appreciated
Old Feb 11, 2013 | 08:37 PM
iboost's Avatar
Anyone happen to have a part number on that?
Old Feb 11, 2013 | 08:53 PM
Again, for which one?
Old Feb 11, 2013 | 09:46 PM
iboost's Avatar
The position sensor. The one circled in red
Old Feb 11, 2013 | 09:55 PM
Should be 12577245. I'm pretty sure that's the most recent number and nothing has superseded it.
Old Feb 11, 2013 | 09:57 PM
BlackARCA06's Avatar
Sub'd
Old Feb 11, 2013 | 10:02 PM
iboost's Avatar
Thanks again man for all the help
Old Feb 11, 2013 | 10:04 PM
No problem.
ashalle2
Sep 16, 2015 10:36 PM
twilson380
Sep 14, 2015 10:52 AM
Rayray2781@gmail.com
Sep 9, 2015 10:40 AM
chris88z24
Sep 8, 2015 01:55 PM
Natoesan
Sep 7, 2015 01:30 PM
