2nd gear Synchronizer went out.
As the Title says. My 2nd gear Synchronizer went out... at least that's what I and the GM Tranny Tech thought. And I'm not sure when or how it happened... (kind of why I posted. I'm wondering if anyone knows anything about the Synchro's.
I was in Dayton, OH. I started my car and drove it from the Hotel I was staying at, to the Northbound I-75 on-ramp. Everything ran and sounded fine. I proceeded to get on to interstate 75 with a cruise speed of 80mph. Traffic slowed me down here and there... but the lowest gear I was ever in was 3rd gear. Along the way there were no funny noises or anything of that nature. I made my way up 75 to the Benchwood Exit... where upon I began my usual downshifting. I down shifted to 4th right away. At 60mph, I downshifted to 3rd... and 40 mph, I pushed in the clutch... moved the shifter from 3rd to 2nd. And it ground the hell out of 2nd gear. It sounded just like I hadn't pushed the clutch in far enough. I was wearing my Marine Corps boots which make it hard to feel anything, so I figured it was my fault. UNTIL, I took of from the red light. Every single time I shift to second from ANY gear... it grinds like crazy. All other gears work perfectly normal just as they have the last 17,500 miles. It pisses me off. The temperature today was 50F and when I got home at 2, I WOULD have gone driving, but since my car sounds like total ass going into second, that was canceled.
Soonest my dealership could schedule me in to tear my F35 apart is Monday! Damn, one ******* problem after another.
I'm curious as to how Synchro's go bad... and any other synchro info. Input appreciated! Thanks.
I have never heard of downshifting hurting a tranny, i have done it in every stick i have owned and never had a problem.
In fact it comes in handy around winter time as you can slow the car down and dont have to worry about locking the tires.
Or what if some guy swerves into your lane when your coasting in neutral, you think you going to have a better change of gettiong out of the way if you just have to hit the gas, or if you have to get it in gear and then hit the gas?
1 Post
I would think that they would have to tear down the transmission to replace them. I would also tell them to replace 2 gear also because it is most likely chipped now.
BECAREFUL with GM dealerships! Had mine in because it would not engage any gear. They removed the trans and tell me its internal and its my abuse that caused it. Well I went to the dealership after hours when I knew service was not going to be there. Sales guy let me in cause I said I needed my insurance card. Inspected my trans and found the shift lever roll pin broken!! No need to even remove the trans at all to do this! Next I had a big fight with the manger who had print outs of threads from this site proving I abuse my car. I was like fine, "Then tell me why you ripped out my trans and told me I needed a tear down when, I grabbed the the shift lever and stuck it in his face, little roll pin was the problem!" He was like ahhhh if thats the problem then we will fix it. So the still charged me $99, BUT I got a FREE car wash!
My 2nd gear is going and unfortunately I have a SS. I took it to my purchasing dealer and they couldn't get it to duplicate. But fast shifting and downshifting(don't do this anymore I'm tired of the grind) you can hear it. So should I wait until it blows 2nd gear replace the stock shifter and take it to another dealership to have 2nd gear replaced?
Originally Posted by Ljavy17
so you dealer said it was the clutch for sure. Sneaky said he had this problem and it was the tluch.
http://auto.howstuffworks.com/transmission.htm
This is a good explanation and visual of how a Manual Transmission actually works. It explains Synchros at the bottom.
That's probably the Synchro as well... What you need to do... is walk in to your service dept and ask for a Transmission tech to come on a ride along. That's all I did.
Which from my SAFC-II guinea pig stage I think I voided everything(GM doesn't know) anyhow.
How can a SFAC void something from ur tranny.
something that's done to bring the RPM's up so you can either get a turbo spooled up or to match the RPM's when downshifting. mostly it's used to keep RPMs up when racing to keep the car in it's power band or turbo spooled
atleast that's how i understand it.
Originally Posted by Cobalt Mav
Sorry to get off topic but what is double clutching?
For a down shift, it's the same only after taking it out of 3rd gear, I let the clutch out, tap on the pedal to make the transmission run at 3k rpm or so... then clutch in, shift to 2nd.
I highly recommend reading through this page:
Explains a lot and uses pictures.
