50K maintaince to-do list
Old Sep 21, 2007 | 08:31 AM
soga831's Avatar
Canada 50K maintaince to-do list
Hey, guys,
I'm running around 50K those days and I was wondering who's maintaining their Cobalts themselves. I hated going to the f**kin "stealer" to let them work on my car, and probably will get ripped of... I change oil and rotate tires by myself, but couldn't find the air filter anywhere, any ideas?
and what's the to-do list for a 50k cobalt???
Old Sep 21, 2007 | 03:24 PM
Novajoe's Avatar
Originally Posted by soga831
Hey, guys,
ummm, I don't mean to bash you or anything... but if you can't find the air filter you should just take it to a shop.
it's all the way to the left of the engine above the headlight in a black box. there should be a few clips around it then the top just slides off and the a/f is inside.
I know your average 60k service includes your normal oil change, rotate tires. It also calls for a new air filter, fuel filter, tranny flush, lubricate the door hinges, replace cabin air filter, inspect the brakes, replace pcv valve, change thermostat and coolant, and inspect the mounts. That's all I can think of off the top of my head.
that being said all of your service intervals should be with your owner's manual. There's a separate book with it that has all your maintenance info.
Old Sep 21, 2007 | 10:43 PM
soga831's Avatar
Thanks for all the infor. I didn't think a/f is a big deal for the first 50k...but there are quiet a few items I'm not aware how to do, any one have like a guide of how to do the maintenance?
Old Sep 21, 2007 | 10:45 PM
rallyracer's Avatar
Where did you find that list of things to change at 50k???
Old Sep 21, 2007 | 10:58 PM
Novajoe's Avatar
I'm pretty sure you're supposed to change the a/f every 15k
I tried searching for a haynes/chilton manual for the cobalt. But nothing. try getting a manual for a late model cavalier. It more or less the same except for some electrical systems.
Other than that try looking through the how-to section
it's a full 60k service
Old Sep 25, 2007 | 08:26 PM
flobeelicious's Avatar
nope, wrong. sig says an 05 ss. which makes it an ss s/c. which means the air filter is a recommended 50000 mile change. and its located behind the front bumper and requires removal of the left front tire and fender liner to unscrew the bottom of the airbox to remove.
Old Sep 25, 2007 | 08:30 PM
Novajoe's Avatar
sry, guess I didn't look into it enough.
so it's one of those full box style a/fs? Replaced one on a focus one time. Costs like $120 for a new one. Would explain why he couldn't find it.
Old Sep 25, 2007 | 09:04 PM
bigrroberto's Avatar
I'm pretty sure that GM sells a complete manual on the car. Just give them your vin# and they can look it up. Whether or not it's worth it ($$$-wise) is another story. I havent yet checked into this, it's just what I heard.
Old Sep 25, 2007 | 09:35 PM
WopOnTour's Avatar
Check you glove box, there's this thing in there called an owners manual...
Everything you need to know regarding the required scheduled maintenance and recommended intervals is in there.
WopOnTour
Old Oct 1, 2007 | 07:07 PM
soga831's Avatar
Thanks for all the info guys, I was wondering if any of ur guys changed brakes already, and how did u do it and how much it cost? I start to hear some noise when braking and thinkin about take it to dealer. They said they need to take a look at it first to decide what to be changed. I know that's not a good sign, so...
Old Oct 1, 2007 | 07:10 PM
Element2.4's Avatar
Pull off your wheels and see if you have any pad left. If your rotors seem grooved then you might have eaten through the pads. What model car do you have?
Old Oct 2, 2007 | 12:00 AM
megaman311's Avatar
Wink
Exhaust System Inspection
Inspect exhaust system for loose or damaged components.
Interval: Every 25,000 miles.
Fuel System Inspection
Inspect fuel system for damage or leaks.
Engine Cooling System Service
Drain, flush and refill cooling system. Inspect hoses. Clean radiator, condenser, pressure cap and neck. Pressure test cooling system and pressure cap.
Interval: Every 150,000 miles or every 60 months whichever occurs first.
Automatic Transaxle Fluid and Filter Replacement
Replace the automatic transmission fluid and filter. (Severe service only)
Interval: Every 50,000 miles if the vehicle is mainly driven under one or more of these conditions: 1) In heavy city traffic where the outside temperature regularly reaches 90 F (32 C) or higher, 2) In hilly or mountainous terrain, 3) When doing frequent trailer towing, and 4) Uses such as found in taxi, police or delivery service. If vehicle is not driven under these conditions, change every 50,000 miles.
Engine Air Cleaner Filter Replacement
Replace engine air cleaner filter.
Interval: Every 50,000 miles.
Spark Plug Replacement
Replace spark plugs. Inspect spark plug wires.
Interval: Every 100,000 miles.
Engine Accessory Drive Belt Inspection
Inspect engine accessory drive belt
Interval: Every 150,000 miles.
Old Oct 2, 2007 | 10:01 AM
soga831's Avatar
I have an 05 cobalt ss/sc. I inspected the pads early early this year, it was still in good shape. I expect it might be waring off a bit... where is a good place to buy those brakes? I haven't found any in my local, so...
Old Oct 2, 2007 | 02:41 PM
megaman311's Avatar
Get hawk pads. You will love them!
Old Oct 2, 2007 | 04:33 PM
ssaddiction's Avatar
hawk brakes are good and didnt read all the posts so dont know if you ever found your air filter so ill tell you how to anyway lol ...ok so you have a ss/sc there airfilters are rediculous to get to haha you have to remove the driver side front wheel and then remove the plastic on the wheel well thats screwed to the front bumper you dont have to take the entire wheel well off once you get enough off that you can work in there just push the plastic back so the rotor holds it out of your way while you work...
im pretty sure there is instructions on how to do this in the HOW TO GUIDE forum search it...if theres a hot to for the install on a CAI then itll show you where it is if dont understand
Old Oct 2, 2007 | 07:09 PM
soga831's Avatar
Appriciate the detailed instruction. I'll need to find some time to either replace it or just take it out and clean it. About the brakes, hawk pads, I live in Ontario, is there any dealer or shop I can check it out?
patooyee
Oct 15, 2015 05:11 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
