ABS light on
Old Dec 14, 2008 | 04:06 AM
_UnLiMiTeD_'s Avatar
ABS light on
Tonight when i started up my car, my ABS light came on, not sure why. Today was one of the first days it got below freezing outside. What would cause this besides a bad sensor?
Could the below freezing temperatures be a reason why my abs stopped working? Also is this covered under my warranty? i still got a full bumper to bumper warranty on my cobalt.
Old Dec 14, 2008 | 04:07 AM
Dead Zen's Avatar
jack teh breaks on icee
Old Dec 14, 2008 | 04:12 AM
the abs dont work, i tried it out
Old Dec 14, 2008 | 01:35 PM
nobody else?
Old Dec 14, 2008 | 01:40 PM
ls1fbody's Avatar
Haz l33t wheelz.
did you check your sensor to make sure its fully plugged in? its possible water got in and froze, popping the clip holding the sensor/wires in. i know when one wheel gets unplugged, the whole system shuts down.
if its anything other than that, the dealer ought to be able to take care of it.
Old Dec 14, 2008 | 01:51 PM
where do i find the sensor?
Also, would this be covered under my warranty or no? If its not i can get it done cheaper at a local mechanic shop rather then a dealer. But if this would be under warranty then i will let my dealership take care of it. The service department isnt open today so i cant phone them, i will have to wait until tomorow.
Embarassing a bit though, i was showin off my car to a few people at a party last night when this came on lol
Old Dec 15, 2008 | 05:18 PM
DaBuzzard's Avatar
The sensors are at the wheels, not sure exactly where but...imo this would be a warranty issue. Unless you ran over something that cut a wire or something like that.
Get it to the dealer, let them fix it.
Old Dec 15, 2008 | 10:37 PM
iLLmaTic3s's Avatar
mine would come on randomly..car went to dealer and they replaced the ABS module.
GutterPalAl's Avatar
how bout you find out what the code is????? then you dont have to shotgun parts at your car.
Old Dec 16, 2008 | 03:12 PM
well i like to get ideas to what it is so when i bring it to the dealer i give them input and let them know that i want it fixed, not just the code cleared. It goes in tomorow morning to the dealership, its covered under warranty.
Old Dec 16, 2008 | 06:33 PM
drop-n-destroy's Avatar
Mine came up today to. Let me know what they find. Another freakin trip to the dealer for me too!!
Old Dec 16, 2008 | 07:48 PM
i post tomorow sometime whenever i get it back lol
Old Dec 17, 2008 | 09:44 PM
ok so update, the hub and bearing on the passenger rear had to be replaced and a sensor, all covered under warranty
Old Dec 17, 2008 | 10:10 PM
Dragonsfire12345's Avatar
samething happened with me... but I was out of warranty. I was given a grace warranty. Cuz I thought my warranty gave out at 40k but it was 36k. Anyways even though they replaced it, my abs and tc light comes on still.
Old Dec 17, 2008 | 10:57 PM
Chad92's Avatar
So I read this, and wondered. So I went out onto my road and got up to 60 km/hr, and slammed on the brakes. Not only did I keep going, my wheels locked up and I was sliding along the ice beaten path, I could hear the tires making noises. I let off the brake and drove it home. No vibrations on the pedal of the abs doing it's thing. Is this normal? My dad's old durango's brake pedal would vibrate to prevent locking up.
Old Dec 18, 2008 | 12:26 AM
u sure yours has abs?
Old Dec 18, 2008 | 12:32 AM
Chad92's Avatar
Every car has to have ABS in Canada, doesn't it?
Old Dec 18, 2008 | 12:41 AM
Tung's Avatar
^nope, some models dont have it (like mine)
Old Dec 18, 2008 | 03:02 AM
nope, my 04 jeep liberty didnt even have that as an option to get, even on the top model
and for the 07 cobalt. it was standard on the ss models but not the ls
Old Dec 18, 2008 | 11:45 PM
lilhomieb07's Avatar
My ABS light came on one day after work. I restarted the car hasnt came on since. Could be a bad sensor, the ABS ground wire could be loose, sometimes if u get water or ice on the sensor itll come on. If it stays in i would take it to the dealer. It should turn off if u restart ur car otherwise u got a problem.
Old Dec 18, 2008 | 11:55 PM
Chad92's Avatar
wow. well that makes me feel safe.
Old Dec 19, 2008 | 04:38 PM
mine never turned off, but its all fixed now, even the humming noise is gone, it sounded like i just had really loud tires so i just assumed this car had a lot of road noise lol. But apparently that was the hub and bearing because now that they replaced that and fixed the abs, the car is much quieter on the highway.
Old Dec 19, 2008 | 09:21 PM
Maven's Avatar
Um....yeah ABS is an option on the LS......I wouldn go doing any 60k panic stops on ice to test anything anymore.
open your hood, look on the frame rail/body behind the drivers headlight, if you have a little metal block with 6 brake lines coming out of it, you dont have ABS. if you do have ABS youll have a much larger(10cmx10cm) box with brake pipes and a large electrical connector.
Old Dec 20, 2008 | 01:57 AM
Chad92's Avatar
Well, it wasn't much of a panic stop. I was on the brake for about five seconds. I'll check tomorrow before I leave for work to see if it's there. I gotta put my block heater cord on the outside so it works when it's -18ºc. :P It's -37ºc here now.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
