ABS light
Old Feb 23, 2009 | 05:31 AM
YellowSS06's Avatar
ABS light
So, I've had a problem recently with the ABS light coming on. It's weird though, because it hardly ever comes on while actually driving. The last instance happened when I was sitting still, out of gear, with both my foot on the brake and the e-brake pulled. The car is an 06 with less than 16,500 on it. Also, the car has never been put through any aggressive braking. Any ideas??
Old Feb 23, 2009 | 05:51 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
It could just be the ABS Sensor.
Mine was doing the same... it ended up being a bad hub/wheel bearing - and we didn't figure that out it until it was too late. Take it in to the Dealership and have them check it out. That's the easiest solution for you with that few of miles.
Old Mar 4, 2009 | 08:59 PM
Lapres_3's Avatar
I have a similar issue right now. My ABS light comes on at seemingly random times usually involving casual breaking. It also goes out at random times. Now is there any other way to see if its the Hub/bearing assy? Any other symptoms?
Appreciate it.
Old Mar 4, 2009 | 09:03 PM
FZWCobalt_09's Avatar
Yeah my abs sensor went out on my back wheel and it came on everyonce in a while. but i would actually loose abs also.
Old Mar 4, 2009 | 09:07 PM
hatrickstu's Avatar
i wonder if mine is still under warranty for that. mine is doing it
Old Mar 4, 2009 | 09:36 PM
sick_ss/sc's Avatar
mine came on and was a bad wheel bearing..i still have abs..but the light never went out..so i pulled the bulb
Old Mar 5, 2009 | 01:18 AM
Mine would come on after my first casual brakeng and i would feel jolts on the brake peddel when barely on the brakes.
Old Mar 5, 2009 | 07:55 AM
JTob's Avatar
That's just the way ABS works, when it detects a fault and the lights on, the abs system shuts down.
Old Mar 5, 2009 | 10:07 AM
Yep
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
z28addiction
Sep 28, 2015 12:03 AM
